Skoda Octavia MkII maintenance & service
What am I looking for?:
- Maintenance & service intervals for the beneath mentioned car and it's parts
What car?:
- Skoda Octavia Ambiente Combi
- 1.4 TSI 122/200
- 2012
What have I found?:
The owners manual which gives the following insights;
- 95/98 Oktan only
- Oil change every 15.000km OR 1 year
- Battery change every 5 years (unless the indicator has no color OR light yellow - change immediately)
- Air filter change every 30.000km
- Fuel filter change every 90.000km
- Spark plug change every 90.000km
- Wheel change every 10.000km
Now as you can see there is quite a few things missing, and although I tried googling it it's tough to get more information than that.
Do some of you have a list or the like that gives an overview over; change x-part at x-kilometers OR after x-years?
Why do I need it?:
- To be able to have an understanding of the cars maintenance requirements & to use cross references when checking the paperwork.
Thanks in advance
Max
First one I noticed is timing belt. I do mine every 50000 miles or 5 years. If its anything like the 1.9tdi do the water pump at the same time.
Alasdair
Alasdair
Thanks! Doesn't the MkII have a chain and the MkIII the belt?
  • Brake fluid change - I think every 4 years.
  • Check/Change coolant
  • Aircon recharge - Every 2 years
  • Oil filter replace - When doing the oil change.
  • Cabin filter
  • Car alarm replace - I think every 7 years.
  • Serpentine belt - If you have one.
If not in the UK then an annual MOT style check.
Brake fluid first at 3 years and then each 2 if doing it.
Pollen filter every 2 years.    AC Recharge, if needed, not every 2 years.
Car Alarm Siren Battery was @ 5 years, they can last 10 years or more.
Spark plugs every 4 years / 40,000 miles,  If you are doing them.
Check the Air Filter every year.
*The cam belt is nothing like with a diesel nor is the water pump, Non Dust Countries were not 5 years / 50,000 miles other than VW / Skoda UK said they were.
Timing chains might last a life time, the tensioners might not.  Actually if the break that is the engines life ended.
Top is what Skoda had servicing showing as up til 2019.
827614452_SkodaFixedPriceServicing.JPG.3dbea7606c029076ed94e2f0216199b6.jpeg.31ad183d3a521d4fac7343de068c47fc.jpeg
129607785_922218293_Screenshot2022-09-2115_58_57.jpg.3711dc86397a804fc83f268add4ae736(1).jpg.e5229dcb612737356407d637c2a22678.jpg.de0b9956eb16c0aa8e5cdf2ed8a184d5.jpg
1787468170_Screenshot2020-11-01at11_56_45.jpg.9e50e5113ff293c688d20c27ca5fcafa.jpg.d19d57ef5af8e885f0eb1d0304e5a6fc.jpg
1039190636_Screenshot2021-09-29at07_53_36.jpg.994d2b104123865330d493df0f73629e.jpg.ca866166fda377bb57b042f179581276.jpg
1025295341_Screenshot2021-09-29at07_53_17.jpg.f3e4a6dc63cb89105f9b1ac440bb1614.jpg.94c996f27eaa950184808025b777ceb5.jpg
Edited by Ootohere
Sorry was thinking of the 1.6 diesel. I think your right mk2 chain mk3 belt.
Alasdair
