Quadlock speakers-only T loom
Hey folks,
just wanted to share this for those who ever plan on adding an external Amplifier or subwoofer.
We all know about the big T loom's for the quad lock connector, which works fine for most.
But i'm a bit of a perfectionist and i don't like a couple of things about the big T loom.
  • No shielding on any of the mic or camera wire, this will introduce noise
  • No twisted pairs on the speaker / CAN wiring, this will introduce noise
  • Big and bulky, making it a tight fit behind the MIB.
So i wanna do it a bit differently.
Inside the factory connector, there is a brown plug. Which handles the speakers.
I removed this part from the connector and built a T harness for the speaker part alone.
This greatly reduces the size of the harness, and doesn't disturb the rest of the factory loom.
Looks neater and is completely removable.
Some companies also make premade looms as this same connector is used in Mercedes Benz and other VAG vehicles.
some notable examples:
https://www.caraudio.nl/artikel/luidsprekerverloop-ql-iso-8-polig-voor-vag-en-mb-ailvqlv_iso
There are some UK dealers too:
https://www.audiotec-fischer.de/en/dealer
(select Great Britain)
I hope this helps people in the future make cleaner speaker output looms.
And please DO NOT CUT INTO FACTORY LOOMS.
The future car owner will thank you.
  • 6 months later...
Hello. Do you have by any chance the part code for the 2 sockets - male and female ? Thanks !!
found them:
Match MQS-Buchsenset | Caraudio-...
No image preview
Match MQS-Buchsenset | Caraudio-Store.de, 8,59 €
MQS-Buchse mit den dazugehörigen Pins
Match MQS-Steckerset | Caraudio-...
No image preview
Match MQS-Steckerset | Caraudio-Store.de, 6,99 €
MQS-Stecker mit den dazugehörigen Pins
I think I will use this one, its easier and cheaper. I will use only the 8pin connecter, the others will be removed from it. https://www.aliexpress.com/item/1005007111279916.html
