Skoda Felicia
Skoda Felicia fan is on, I want to make the LED, when the fan is on, the LED will turn on and off, thank you, please inform me.
okay get a 12v indicator light ground one side and get power out of the thermoswitch 2 wires 5min install
A diagramme would help far more, before few years in a Skoda forum a member had made a scheme for this but the forum closed at 2023 and i don't think i can find it.
It's very helpful to have and indication when the fan is On and Off, may prevent a disaster.
Did you particularly want to use an additional (LED) indicator lamp for this? In my pick-up I have the heated rear window tell-tale in the instrument cluster wired to show me when the radiator fan is on.
AkedThank you very much friends, today I took a plus-minus cable from the fan socket, I tested it and it worked, all that is left is to take the cable inside, this will be the most difficult part 😉
Hello Skoda Felicia, is it necessary to remove the light-cutting metal sheet inside the headlights of LED headlights?
To do what?
The led indicator for the radiator fan has nothing to do with the headlights.
