288mm to 312mm brake upgrade
Hello everyone, I want to increase my brakes from 288MM to 312MM is this possible?
I understood that the caliper remains the same.
What do I need to replace?
It is a Skoda Fabia year 17 engine 1.2 automatic
Other than you want too, which is fine, are there other reasons, you don't have to say but if it's a braking issue there might be other solutions and answers.
Is there space within the rim for larger diameter discs, the standard discs are very close to 15 inch rims.
Based on other replies, if you have 15" wheels, 312mm discs (well the brake callipers) won't clear the wheels.
If you have VAG 16" or larger, you need new calliper carriers, discs and pads.
What are you trying to achieve?
Thanks. AG Falco
