Pr code
Looking for the PR CODE on a 2016 skoda rapid space back SE sport. Can't find it on the stickers or service book. Any ideas - thanks.
Also add it's aTDI - code is either 1ZC 1ZG or 1ZY.
So, it is the front brakes option that you are asking about, I'd think that it will be 1ZC - check the front callipers, if they have a vertical anti rattle spring fitted, then they will be 288mm discs and so PR-1ZC. If on the hand, there is no vertical anti rattle spring fitted then they will be Mando equivalent of FSIII.
Thanks for getting back to me - it's actually a wheel bearing kit we are trying to order - do you think it will be a 1ZC too?
Yes, if the brakes are as rum4mo described.
Genuine part number for bearing was 6R0407621A, superseded by 6C0407621.
You may or may not already be aware that this is a Gen2 type bearing that needs special tooling to fit. See e.g. GEN2 Wheel Bearing Removal Tools | 2nd Generation
Just pressing the whole lot in by the hub face will likely result in failure and damage to the bearing.
I sourced new front bearing assembles from AutoDoc - F A G 713 6104 70 and bought a cheap (China sourced probably) tool that is for 72mm bearings, that worked out fine, I just replaced both sides, I managed to avoid trashing the LHS ABS sensor but was not so lucky on the RHS.
Paid too much at that time for a new Bosch sensor from ECP, better to source them from somewhere like PIM or similar, lesson learned so maybe avoid that error!
