CarPlay won't connect - shows "no playable files" error
Any suggestions? 2018 Fabia.
CarPlay has stopped working. Won't show CarPlay at all - get message "No playable files". Have tried with 3 different iPhones, all have the same issue.
It has happened before and I sorted it by removing the iPhone from Bluetooth in the car, removing the car from from Bluetooth and CarPlay on the phone, then connecting again. Cannot make it work this time.
I can connect via Bluetooth again but get the "no playable files" error message when connecting with a cable.
System information:
Bluetooth: C190
Android Auto: S1.3_A8755
CarPlay: 210.81
MirrorLink: 8755_ml_2016_11_01
Device part number: 6VO 035 869H
Hardware: 690
Software: 8755
Try resetting your infotainment unit to facory settings.
Had the exact same issue after I bought used Fabia 2021. Car should have Apple CarPlay, it's version was listed in the menu but it's logo was missing on the SmartLink screen (there was only AndroidAuto and SmartLink logo for some reason)...
You can only reset parts of the infotainment by going into the settings - factory reset - SmartLink.
For me, factory reset of SmartLink helped - Apple CarPlay logo appeared on SmartLink screen (the screen that appears after clicking the app button) and CarPlay connection through cable was suddenly okay and everything works fine.
Now resolved. Thanks for the responses.
Reset Smart link to factory settings. CarPlay now there again.
