Brake servo vaccum hose part number. 1.2HTP or equivalent pipe.
Hi there been trying to find a part number for the rigid plastic hose from brake servo to manifold including non return valve. Does anyone know the part number or an equivalent flexible hose as mine is completey gone. Its an 06 plate fabia mk1 1.2HTP. RHD
Alasdair
  • Sponsor
Part number is written in white all along the hard plastic section. 6Q2 612 041 and then a couple of crucial letters. The letters are the only difference between a bunch of different types for different engines.
Many thanks will have a good look. Its split at every connection. I did tape it up but not getting a decent seal. Car pinged up EML Read codes with a cheap reader and reset and so far hasn't returned. Not sure if they are related
16825 EVAP emission control sys incorrect flow sporadic
16490 Manifold pressure sensor G71/F96 implausible signal sporadic
16891 Idle control system rpm higher than expected sporadic
Checked all pipes and they seem fine but servo pipe not good. Taped it up again and so far so good but needs replaced.
Thanks again
Alasdair
