Skoda yeti glow plug/engine light
I have a skoda yeti 2011 model having some issues glow plug/engine light blinking same time.
to fix this issue I have done the following things.
  1. changed Glow plugs.
  2. Cleaned EGR value, EGR vacuum actuator was broken its fixed now.
  3. checked all the lights.
  4. Laptop diagnosed its just showing radio fault code, rest all okay.
  5. High Pressure pump changed.
Crikey. I get that all the time and just ignore it...
What program are you using to read fault codes?
Edited by Hs82
