Display showing boot open when closed and warning chime sounding when driving - Skoda Superb MK3 SE with power boot
Sorry not been on this site for awhile
The only thing I get now is if I open the glovebox the dash indicates the the tail gate is open and I get the binging sound and when I close the glovebox it stops. Small price to pay for it only being that and not everything else that it was doing.
Oh wow, yes definitely a wiring issue there.
Mine is definitely something to do with the buffers and striker bar.
If I use a screwdriver to simulate the bar closing the latch, it clicks into 1st position and then 2nd closed position fine and the car says the boot is locked and closed, so the latch sensor is fine.
I have it now where it closes, pulls down but is about 2mm not doing the 2nd click fully via the pull down.
I have a suspicion that the bar itself is too thin. going to add some tape as a test to increased the diameter of the striker bar and see if that works
This can happen if you replace the boot lights with cheapo Chinese LED’s. I know, I’ve done it but I live with it on the basis that I can actually see inside the boot in the dark!
It is fairly easy to obtain led replacements that do not cause electrical issues though.
I have some from Ali express that have caused no issues at all.
https://a.aliexpress.com/_EJ0uxgm
True and I’ve fitted those “CANbus friendly guaranteed not to trip a warning” in the past and of course they’ve still caused the same issue and, TBH, I’m not prepared to pay the £35-odd difference for the ones at Kopeck to stop an occasional “bong” when the glovebox is opened. I know, I can’t help it!
Yep, those’ll be the one I have and still have the same issue. 🙄
Yep, I live with that too!
So did you resolve the issue.. my Superb is doing the same kinda thing.. I don't get any dings but sometimes the tailgates does not pull in and close... and sometimes it does, but if it doesn't I get the tailgate open warning in the middle of the dash cluster and I need to get out, open the tailgate again and close it but when it's about an inch away from the latch I give it a little helping hand and it closes properly.
Doesn't happen all the time tho..
Hi I now only get the warning on the dash cluster and the dings when the glovebox is open which I can live with.
I cannot find anything else I can do to stop it.
I have a suspicion that the bar itself is too thin. going to add some tape as a test to increased the diameter of the striker bar and see if that works"
Did this fix the actual closing fault?
Folks,
I was getting intermittent warnings that my boot was open whilst driving, and the locking mech kept cycling.
It was the washer fluid sprayer on my reversing camera that had popped out of the reversing camera housing and was squirting over the internal boot lock electrics.
Have a look at my old posts for a write up & photos of how to fix it.
