Mk3 Fabia Build
Hi all,
I’m planning something a bit different with my Mk3 Fabia Monte Carlo (2016, 1.2 TSI, 6-speed manual) and wanted to get opinions from the community on feasibility.
The idea:
Swap in a complete 2.0 TSI EA888 Gen 3 engine (from a Golf GTI/R donor car), along with its 6-speed manual transmission, ancillaries, and ECU. The aim is a proper drive-in/drive-out conversion with supporting mods:
IS38 turbo (stock Golf R unit)
High-flow FMIC, intake, and turbo inlet
200-cell sports cat downpipe exhaust.
Coilovers (Bilstein B14 or equivalent), uprated mounts & bushes
Golf donor brakes + uprated pads, braided lines, RBF 600 fluid
Target: ~370–390 bhp / ~430–450 Nm (kept within safe limits of the MQ350 6-speed box).
Has anyone seen a Mk3 Fabia with this swap before?
Are the Golf/Octavia mounts, shafts, and subframe geometry close enough for a “bolt-in” fit, or is custom fabrication unavoidable?
Any known CANBUS / electronics nightmares (ABS, ESP, cluster, immobiliser) I should watch out ? Just want to sense-check before I dive in.
Hi, welcome.
Whilst if you search this forum you will find this sort of thing has been covered here before you might find more like-minded people and information by looking and/or asking in the 'Fabia Projects' and 'Performance & Tuning Upgrades' forums of Briskoda.
HTH.
'Fabia Projects' forum. - https://www.briskoda.net/forums/forum/205-fabia-projects/
'Performance & Tuning Upgrades' forum. - https://www.briskoda.net/forums/forum/212-performance-tuning-upgrades/
On 17/08/2025 at 16:38, RazzleDazzls said:
Hi all,
The idea:
AFAIK the swap has never been done, Only seen 1.4TSI Swaps. But, From what i've heard, a 1.8TSI swap is entirely possible given a full donor car is available, also aftermarket immobilizer i think too, so I dont see why the 2.0 wouldn't fit.
The 1.8 and 2 litre ea888 engines will both fit, I was considering this swap but stuck with the 1.4 swap due to time attack competition regs saying I can't have anything bigger than 1.6 in the pocket rocket class.
You can use all the engine/gearbox mounts from a 6c polo gti to make the 2 litre engines fit, but you will need the full wiring loom from a donor car, or at least have someone re-pin your body loom to work with the simos ecu for the ea888 engines
Edited by TheFozzy
@thomasaspin is the person with experience of putting 2 litre engines into Mk 2 Fabias.
