Skoda Scala with Acc Vcds Auto scan
Just now, Vincent_83 said:
I haven't retrofited yet this function on my Kamiq, but just searching a lot of information.
For my side, I have a separate gateway module because I have the High BCM
Bummer
If you decide to install it, i have the auto scan and the adaptation of a bcm (high?) and the software for the swap function, maybe you can get it done on your car. The bcm on that car is 2q0937090D
5 minutes ago, SUBZER0 said:
Bummer
Mine is 2Q0937090E (D version is also "Standard Plus" version (High) (AW4)
Edited by Vincent_83
https://mega.nz/#P!AgBDv0fNLhDxADcVZB4_YlmHhQZ4FzDlKVVLJZ4J64bj0iKdPPC3lwi1Bjj76OsGsBB_5rsKwWSm7tEOWP4nUOVGRQcEQVyPZnAaxR5aUACdAbSObK06Jg
1 hour ago, Cairus said:
You know that the Scala and Kamiq without ECU 16 also have ACC? However, you have a BCM that has the gateway integrated, probably mid-version.
I think this is the Problem
From what I understood from the wiring diagrams, the BCM connects certain components (particularly the switchgear) in the absence of adaptive cruise control.
I didn't know it was possible to have ACC without the J527 ECU.
1 minute ago, Cairus said:
What is this ? There is a protection password on this megafile
I know, my Password...
SwaP ACC solution
SwaP ACC solution
Ahh, that's very interesting.
Can you please tell me your password to decrypt these files ?
You have the Controller R242?
Yep, I have Front Assist, Lane Assist and TSR from factory.
And I have retrofited Side Assist and Park Assist and I hope one day, I'll retrofit ACC
You have the Connection between?
No, I had disassembled the R242 camera to check something else and on the connector, I only have one pair of CAN Extended wires (the ones that go to J519)
Don't tell me that just adding these 2 wires makes ACC work ?
You need them
3 minutes ago, Cairus said:
You need them
I can add them, it's not difficult.
But I don't understand the way. Can I contact you in MP to have more information Cairus ?
I did make one mistake, though. I apparently had a different car in mind regarding ACC without unit 16. Scala will have it as soon as ACC is available. Sorry for my incorrect information on this.
MP?
MP?
MP : Message Privé (in french) Private Message
No problem for the information, although I admit that I would have been happy to be able to install the ACC without all that to do 😁
What you need?
So, i found Kamiq 2023 with ACC on my Server...
Unit 16:
Hardware-Nummer
5Q0953569F
Hardware-Version
100
Software-Nummer
5Q0953521MG
Software-Version
0275
Seriennummer
20240124500556
Lange Codierung
6404
Unit 13
Hardware-Nummer
2Q0907819
Hardware-Version
H03
Software-Nummer
2Q0907567B
Software-Version
0534
Unit 09
Hardware-Nummer
2Q0937090F
Hardware-Version
H15
Software-Nummer
2Q0937090F
Software-Version
0982
Unit 03
Hardware-Nummer
2Q0614517CB
Hardware-Version
H20
Software-Nummer
2Q0614517CP
Software-Version
0120
Unit A5
Hardware-Nummer
2Q0980653A
Hardware-Version
H19
Software-Nummer
2Q0980653G
Software-Version
1505
Unit 19:
Hardware-Nummer
3Q0907530BA
Hardware-Version
542
Software-Nummer
3Q0907530BB
Edited by Cairus
So my installation is correct? I kinda got lost in the discussion
