ODB port not connecting to scanner
I have a 2010 Fabia 1.2 and the ODB port isn't playing ball. Tried 2 different scanners and they both fail to auth with the ECU. I initially thought it might be a bad fuse so I replaced num 22, didnt change a thing. Slipped the port out of the dash and made sure that the wires are fully seated in the connector, no change. I've tried with electrics on and also engine on, doesn't make a difference.
Does anybody have any suggestions on what to look for next?
Check the voltage at battery. If its too low then OBD sometimes won't work and make sure that the fuse is making good contact. It should be OBD2 but as its can bus maybe older scanners won't work?
Alasdair
Do you have an aftermarket radio? like an android unit? If yes, it could be that the head unit is connected via can and taking priority of the can system and not allowing the obd reader to connect to the can line. This happened to me on a 2013 fabia while i was tuning the ecu and I wasn't able to connect via obd, disconnected the head unit and everything was working.
Alasdair
I've tried 2 different scanners and they both failed to connect. Haven't checked the battery but I do have a multimeter in a box I can dig out!
Nope it's the bog-standard CD player jobby, nothing aftermarket in the entire car!
I could disconnect the fuse for the radio and see if that makes a difference?
ok, you can try to disconnect the battery for like 10-15 minute connect it again and try (i don't it will solve but worth a try) more effective look behind the obd port for broken or sliced wire
Might be that the obd port isnt connecting to one of the pins on the reader. Had problem years ago and the obd socket wasnt making proper contact with the pins in the reader cable. In my case there was dirt/corosion in the cars OBD port. I used a pin to clean and made sure the spring connectors were tight and it came back to life. Check that your actually getting 12v to socket in car and also the earth is good. Sorry not sure what pins are which think pin 16 is 12v supply and 4and5 are earths.
I had a look the other day, all wires look fine and I made sure they were all pressed home as much as I could.
I will check the readouts when I dig my multimeter out.
Hope its something simple. Old car electrics were bad enough but new ECU based stuff is getting way beyond me. Check all the fuses related to ECU as well. On my sons MK1 there are a few that are linked to ECU. Car could be going through a process before connecting and getting stuck.
Used this but not sure how accurate it is but was fine for my sons to find fuses etc. His main strip fuse for brake/ABS had cracked.
https://www.startmycar.com/gb/skoda/fabia/info/fusebox
Alasdair
Hi, I've had fabia 2009 level 1 trim for almost year and half now and been experiencing similar issues.
First of all my obd port doesn't work properly with cheap scanner also well known apps powered by obd2 scanner.
I also occasionally get abs fault popping up, but it happens at random times, sometimes nothing for weeks. Could you explain which fuse to look for? Is it by the battery?
ABS I think on my sons mk1 is a strip fuse in front of battery. His are individual but I think later models had a sealed fuse pack. There prone to cracking but difficult to see any cracks until removed. His ABS brake warning lights includiing warning chime(bloody loud) used to come on randomly. The fuse had a hairline crack that broke contact from time to time. It could also be a dodgy ABS sensor or wiring. Difficult to work out when the scanner wont connect.
  • 4 months later...
Is there anyway to find out ? Obd doesn't seem to connect even it has a port.
As mentioned near start of post do you have an aftermarket radio? Some can interfere with OBD connection. As for ABS sensors the only way is to scan car to find out which one unless you replace all four but it could also be a failed sensor ring in bearing or bearing itself. Check the wiring to each sensor and the condition of the connecting plug plus feel for roughness in bearings.
Alasdair
Well to flog the dead horse somewhat, the ABS light pinged up today (first time ever). Scanner doesn't connect still.
What I HAVE noticed though is that my fuse strip next to the ODB port seems to be the wrong way round to the diagram on the back of the panel (and the diagram link above) - the fatter fuses are to the left and the smaller ones to the right (which doesnt correlate to the diagram). Is this potentially the reason why nothing is working (because someone in the past has 'fiddled' and put it back incorrectly)?
  • Sponsor
No, you just have a RHD car instead of the LHD the manual pictures.
Fuesbox is just rotated 180°, in the factory.
  • Sponsor
Well that seems a bit stupid tbh! You would think they would put a RHD diagram on the cover...
1 minute ago, Breezy_Pete said:
Thank you!
  • Sponsor
Yes, it causes owners in RHD countries plenty of head-scratching.
Cost saving.
I've done some multimeter checks today. Pins 4/5 > 16 show roughly 12.4/12.5v (expected).
Canbus shows 2.5v (expected)
6 > 14 resistance check is 65 (higher than expected, norm 60/61)
Would the 65 be an indication of a problem somewhere? The port has power on all the pins I would expect, but perhaps there is a small issue further upstream which is causing it to not connect?
If all else fails I will ask an auto electrician to have a look - hopefully they will have more tools and experience with this sort of thing!
Just checked the system again, both CANBUS pins are showing EXACTLY 2.5v when the system is active (key turned, radio on, engine off) and also inactive (key out). I'm led to believe that there should be a very slight voltage difference (2.7/2.3) between the 2?
If this is the case and this is the issue, any recommendations on how to fix?
Hi, I previously had an issue with abs fault and obd not connecting. I hope this will hell someone.
I was previously using "cheap" obd2 scanner together with multiple obd scanner apps. The scanner would not connect when fully inserted until I found out a certain way to have it not fully in but obd pins touching scanner.
Then when I got it working, the apps such as carista and other free apps would not diagnose anything related to abs.
I then used friend's profession scanner which worked when fully inserted as should be. That diagnosed abs fault.
Then I bought my own Kingbolen ediag elite obd scanner with Lifetime updates. This app actually worked with mk2 2009 and showed the abs fault finally.
The fault: rear left abs sensor showing up. Changed abs sensor which didn't help - next possible solution is the abs ring in the bearing hub. I hope this helps someone.
I have a Topdon AL400 (which is compatible with the k-line diagnostics) but it's not being detected when plugged in (but is on the other car, so I know it works).
I have a suspicion that when the ignition barrel was changed by the previous owner (at a garage) before I bought it, they damaged one of the wires. I think I might need to go down the route of an auto-elec to diagnose the fault. I don't have the expertise to work out what's wrong with it and I don't want to butcher the wiring in an attempt to find out what went wrong! I think it's a damaged cable somewhere that has caused a canbus short (resulting in the 2 lines having 2.5v each plus the resistance of 64/65).
If anyone has any suggestions on companies/individuals in the swindon area that can properly diagnose/fix this fault, please do let me know!
Most modern cars use the CAN bus system, which uses 2 cables to connect to all the ECUs in the car. The older K-line uses a single cable and is much slower in its comms between ECUs.
It could therefore just be a simple case of the cheap device you have not being fully compatible with the apps and/or the ECUs on the car.
I myself noticed that many of the really cheap devices on sale have cut corners and I purchased many of these before deciding to bite the bullet and purchase both the VCDS and a more upmarket and thus capable OBDII device, in my case one by Carista.
The VCDS is by far the more capable one but is also not for the complete novice, as it is so powerful and demands far more from its user in order to do things. I'm still learning how to actually use it correctly, whereas the Carista and its own app are far more user-friendly.
Hi Graham, thanks for the detailed reply! I have a topdon scanner and also utilised one that a mobile mechanic had - no joy on either. I've checked the port again today and I'm seeing 3.4v on the k-line pin instead of the expected 12v. The handbrake light is also now flashing when I turn the key, but that might have been cos I was checking fuses!
I have an offer from someone who lives nearby with vcds, so will see if it will talk to that!
Oh that's good keep us informed how this goes.
When say you are only seeing 3.4 volts, that may be correct, the car battery is 12v but comms line between ECUs is not a normal standard 12v DC supply, it is being modulated by the ECUs talking to each other.
The other thing to bff e careful about on cars is being h mindful of the type of meter used to measure voltages, digital meters can provide false reading on certain parts of cars. This why you often see test lamps or older style analogue meters being used as they present an actual loading on the circuit. So ghost voltages caused through tracking on corroded connectors will tend to collapse to almost nothing when the load is applied. Digital meters do not exhibit this loading.
