skoda superb 2.0tdi not reaching operating temprature
On 27/11/2025 at 17:15, franko02 said:
Update. Unplugged the auxiliary water pump and the car reached operating temp. I went looking in live data and the temperature for the egr cooler says -270 degrees. I would relly like to know what the temperature is on other egr coolers according to the live data reading.
A negative reading on the egr cooler sensor could suggest the sensor is faulty ? I'm not too familiar with the arrangement but assume the sensor could be replaced. Maybe it is failing safe and causing the aux pump to run continuously and over cooling the engine ? Just a thought...🤞
  • 6 months later...
Replaced the DSG T-stat a second time with an oem VAG. Problem is still not fixed. Just thought i got a bad dsg stat in the first place. Havent put in the hotter 92c mhale T-stat yet. That will be the next step. Will keep you posted.
