Problem starting the engine Kamiq 1.0 Tsi
Maybe the fuel pressure regulator if the kamiq has one thats either too low or high and is pinging up code?
Alasdair
Where can I find this pressure regulator?
10 hours ago, mlody38 said:
I checked the pump and it works for a few seconds after turning the key.
That should prime the system, if so, then if you switch off and try it again say 5 minutes later and probably far longer then you shouldn't hear it priming again?.
That's right, buddy, after turning the key again, you can't hear it. So I think there's pressure in the system.
I think the pressure regulator is part of the high pressure fuel pump on the 1.0tsi. On earlier engines it is separate. On my sons fabia 1.2 I am pretty sure its part of the fuel filter. Not sure how to check. May need specialist equipment to check pressure while running VCDS.
Alasdair
Hello, after continuing to search for the cause after unplugging the ECU connector, it turned out that the yellow/blue wire is disconnected. It's likely that the wiring harness was bent and a break occurred. Now I need to locate the break. Thank you all for your help in solving this problem.
  • Sponsor
You could just cut the wire near to each connector and add a new wire linking the two.
(Check that the parts you have cut have continuity to their nearby connector before joining them.)
Edited by Breezy_Pete
Great idea, buddy. Thank you so much for your help and sharing the diagram.
