Starting and stalling problems
Can anyone help, my skoda octavia 2006 1.6 fsi keeps stalling, I've replaced the throttle body actuator, camshaft position sensor, vvt solenoid, map sensor, maf sensor, air filter, oil change and filter, fuel filter, o2 sensor. What else can it possible be
Have you checked the spark plugs?
Yeah I've replaced spark plugs and coils
Yeah spark plugs and coils were replaced aswell
Vacuum leak somewhere? Any check engine light?
1 hour ago, Robert@78 said:
Can anyone help, my skoda octavia 2006 1.6 fsi keeps stalling, I've replaced the high pressure fuel pump with cam follower, throttle body actuator, camshaft position sensor, vvt solenoid, map sensor, maf sensor, air filter, oil change and filter, fuel filter, o2 sensor, spark plugs and ignition coils What else can it possible be
I did have check engine light come on but since disabling the battery it has disappeared
Oh and I've had a look at the vacuum lines but don't see any signs of cracks/splits 😭
Stalls while idling or driving or both?
Crankcase "breather" valve faulty?
There might be plastic piping that sometimes crack and are almost invisible but these generally cause a fast idle. ( I think you've covered that, above)
Can you attach a vacuum gauge somewhere on the inlet manifold.?
Edited by Johngerard
It does it when engine cold/hot idling and driving, but sometimes it drives fine for a few miles
Can you describe how it cuts out.
Eg
Splutters
Looses power
Slowly dies off
How does the restart go?
Eg takes heaps to get going or starts instantly
Sounds electrical to me
I would get it scanned with vcds and see if there are any random codes stored. It does sound electrical but could be fuel related. Check the strip fuses near battery compartment. If there individual check for hair line cracks/corosion etc. It could also be a failing relay for fuel pump etc.
Alasdair
Eg
Splutters
Looses power
Slowly dies off
Eg
Splutters
Looses power
Slowly dies off
It goes like a rough revs then dies aslo it starts fine but takes afew attempts but then it dies again and this can happen 10+ times
Alasdair
I've just brought one of those cheap obdll scanners as money is tight at the moment, just waiting to see if any check engine lights appear again, I will have a look at the fuses and relays and check them with my multi meter
Another thought might be did you code/calibrate the throttle body after replacing actuator? Not sure but think you need to use VCDS to tell the ECU the position etc.
If its not coded then it may lead to rough idling and stalling.
Alasdair
Alasdair
I was told to disconnect the battery for 30mins and let the cables touch each other to discharge the code, and then I connected them back together turned the engine over and let it idle for 20mins so the ecu could calibrate the throttle body
Think it may need VCDS or OBD2 to do it but came accross this on a VW forum. Not sure if it will work on yours but cant see the harm in trying.
1. Turn the key to the "ON" position, BUT DO NOT START THE CAR!
2. Leave the key in the "ON" position for 3 minutes WITHOUT TOUCHING ANYTHING.
3. After 3 minutes, turn key to the "OFF" position, then start the car as normal.
May have to be done with bonnet fully open.
Alasdair
Meant add disconnect battery neg for 15-20mins then reattach before the above procedure.
Alasdair
Alasdair
OK brilliant thanks I
Alasdair
OK brilliant thanks I will give it a try
Still stalling can't find any vacuum leaks but I've noticed that it's mainly stalling when the engine has warmed up
Maybe a compression test in order?, it may, (hopefully not), be a sticking inlet valve.
It may be the throttle body as previous. I would get it properly calibrated with vcds to rule it out. There may well be someone on here local to you with it that could give the car a proper scan and calibrate it for you. If not then you may have to source a VAG specialist garage or at lease one that knows how to and get them to scan it. It may pinpoint a prroblem that your scanner is missing.
Alasdair
Was it a good quality crankshaft position sensor?
Yeah it was 👍
1 minute ago, Robert@78 said:
Don’t want to send you down a hole but I have heard of new ones being faulty. Unlikely if it’s good quality but not unknown.
