MIB2.5 Firmware update Software 1163
Currently doing the Maps which are from when the ca was produced - 2018.
With this in mind I have the following -
Hardware H54
Software 1163
Is the software as old as the car, 2018. If so what would be the update process and where can I get the files to do this.
Stick your VIN into https://updateportal.skoda-auto.com and you'll be able to download it.
I'll be around 16GB zipped, which will expand to ~22GB unzipped, so you'll need a 32GB+ USB stick or SD card (both SDHC and SDXC is supported).
Is that for the satnav maps only or is that both?
That’s for Satnav maps only.
You extract (prefer 7zip over winzip as the latter can cause a checksum error) to the stick/card and then leave it plugged in. It breaks down the file into loads of chunks and sets lots of bookmarks/savepoints so when you drive short journeys and it doesn’t finish a segment it doesn’t need to start again, just picks up from where it last saved.
Just keep checking your system page and eventually the navigation database number will update.
Be careful when performing a firmware update. If you switch from G11 to G13, only the large 9.2" display will work with the radio.
I have the G13 already, just done the firmware update via @JR RS doc and it worked, now on firmware 1440 from 1163
Everything seems to work so far
Doesn't work with my SD card doing the maps
Have noticed now I have the SOS Emergency call restricted. Workshop
Has now appeared, SOS button works as it was about to call before I manually ended it
So USB stick then
Just now, travs said:
So USB stick then
Yes indeed, used the same stick for the Firmware and the maps
Just got to sort this SOS error which appeared as soon as the firmware update started
No Diagnostic Tool?
8 hours ago, Cairus said:
No Diagnostic Tool?
Ordered one from Amazon, so hoping that can reset it
Tools from Amazon didn’t seem to work but holding down the power button on the stereo seemed to work today
