Automatic Wipers Not Activating in Rain
Hello everyone,
I have a 2021 Škoda Octavia (Mk4) and I am experiencing an issue with the automatic windscreen wipers.
When the wipers are set to automatic mode with the sensitivity at its highest setting, they do not activate when it begins to rain, regardless of whether the rainfall is light or heavy. As a result, when it starts to rain lightly, I have to manually switch the wipers to the “on” position, which is too fast for the level of rain.
In addition, manually activating the front wipers also causes the rear wiper to operate too frequently. After one or two wipes, the rear wiper begins to drag across the rear window, which is not ideal.
I have attempted to diagnose the issue by pouring water from a bottle onto the rain sensor at the front windscreen. In this scenario, the wipers do activate automatically and clear the water as expected.
I am aware that the front windscreen was replaced before I purchased the car, so I am wondering whether the rain sensor may have been damaged or incorrectly fitted during that replacement.
Are there any other tests or checks I can perform to better understand what might be causing this issue?
Thank you in advance for any advice.
It does sound like the auto wipe has been affected by the windscreen replacement.
The rear wipe can be turned off in the settings. However turning that off also disables the rear wipe when selecting reverse gear 🙄
It would be worth checking all the wiper settings too.
This for the rear wiper…
Thanks for your reply. I have turned off the rear wiper in the settings and has made a huge difference.
Here is a picture of my windscreen with the sensor. Does this look like the windscreen replacement is the issue?
Unless it's just a reflection, that round sensor looks wrong and could be the problem.
Thanks. Not a reflection, that's how it always looks. I'll let the dealer know that this could be the issue.
