2015 Scout Rear Diff Failure - Options
Just been delivered the news from my garage that the rear diff has failed on my 2015 Scout and is the reason for the increased road noise I've been getting (recently pretty bad).
Will be having a chat with him in the morning where he'll show me what he thinks but he's not dropped the oil yet to see what condition that is in or how much in the way of metal fragments there are in it.
I'm thinking the worst right now but also wondering what likely scenarios there are and what options might be open to me.
I should imagine that a new diff is hugely expensive and not worth it for the value of the car. (2015, bought 3 years ago, currently 120k but otherwise in v good condition).
I've heard talk on hear of diff bearings going and this being a relatively cheap fix (compared to new diff). Is it possible to diagnose this being the issue without removing and stripping the diff.
I'm not sure I want to be undertaking potentially costly exploratory works to find that its not fixable relatively cheaply and a whole new diff is the only answer.
I have found some (online) a few gearbox specialists locally to me (in Sheffield, UK). I'll be contacting them to see what they think.
I feel like I'm facing either a potentially huge and unknown bill or being stuck with a worthless car and having to start searching for something to replace it.
Is there any value in one of these with a bust rear diff?
Is it possible to remove altogether and carry on using as a fwd octavia, or is that just silly talk? I know I'm probably clutching at straws but funds are limited and need a decent sized family estate. Sort of regretting getting a scout now. Broke my first cardinal rule when I bought it of not buying cars with additional, complicated extras... usually prefer to keep things simple and didn't this time... doh!
You have to seriously abuse a rear diff to break it, but I suspect that somebody has accidentally drained the Diff when they wanted to clean and drain the Haldex. Its a common think done by technicians who aren't aware of this trap. The fluids are completely different and if you put Haldex fluid into the diff, you can easily break it.
Is it worth taking it to Darkside Developments to investigate as they're a diesel VAG specialist and run many overlanding vehicles? so should have a very good knowledge of the VAG haldex 4x4 setups
Thanks Matt. They're not too far away from me.
So far I've sent messages to:
Mr Gearbox (Sheffield): They seemed open to looking at it.
M&T Transmissions: No response yet but the garage I went too had had some bad experiences with them.
Sheffield Gearboxes: Had no experience of working on these so not considering that one.
No experience of any of them.
Worryingly, when on the ramps at the garage it was at, they pointed out that it looked like the haldex filler plug hadn't been out for a long time, despite supposedly having had a haldex oil change at my local garage last year.
I just put on a post without finding this post. Please refer to that.
I was speaking to Geartec Midlands, who have an excellent reputation in the trade. They said this same diff, with different ratios, is used through all the VAG 4x4 range. Failure is well know to them.
Interesting idea about not using the rear diff, but can't see how you can do it. Maybe just remove the drive shafts. However the traction control will want to put torque through the Haldex when the front wheels slip. I would imagine one would get traction control error messages. Also the dodgy diff bearings are still in use, albeit with little load on them.
I've heard of them breaking a fair amount, but IMO this is mostly due to servicing issues.
Removing the rear diff from the equation is mechanically possible, but will make the car very unhappy. Without adapting anything, I suspect it will just throw a million fault codes, tell you about a 'drivetrain error' and whack you into limp mode.
Hi Martwek, Id question the diagnosis of a failed diff before they have drained the oil to see what is going on. They may be right but sometimes the "you need a new one" is quick solution to solve a mystery rather than digging further.
Id want to see the oil, what it looks like, if there is any swarf in there, so as a first step Id do an oil change to see if that helps. At the same time Id want the haldex oil changed and the internal filter removed and cleaned as that step is often overlooked but a good VW independant will be able to sort it.
As a fellow scout owner the 4x4 system can be a bit noisy as it ages, id even call it a bit of a whine but it doesn't necessarily mean its failed.
Hope this helps
