Skoda Felicia 1.6 how to replace part number 6U0711248
Hello. I need some advise how to replace damaged shift cable bellows, gearshift joint cuff, part number 6U0711248. Anybody have some experience with this repair.
I have done it in the past in my 1.3, replace everything with a kit (not just this part).
Yes this is also the solution. But how did you put the pieces together? Did you receive any user manual for these parts to assemble?
Edited by JohnNovak
text correction
  • 8 months later...
I successfully replace this rubber and 2 pieces of o-rings.
The ''feeling'' now is better when you change gears?
My gear stick sense was very sloppy plus i has a problem in 3rd gear,it was shaking a bit and i always afraid that it will be disengage by itself. 😄
I did not replace any gears , just rubber and 2 o-rings.
The feeling is a little better but still not as new.
You should change everything you could taken from a set like this,
was an A' class opportunity since you started the project.
