Pin assignment
Hi & good afternoon.
I'm trying to find the pin assignment for fabia mark 2. T28a connector & or the female socket as well. I have purchased 2 manuals from different companies thinking maybe the first manual didn't have it for some reason no joy. I have tried many variations of what this connector is or could be called in & around the internet no joy. I found pin assignments to everything but.
If someone could point me in the right direction. Give a man a fish you feed him for a day. Teach him to fish you feed him for life. If you see what I mean. Hope help is just a click away. Thanks in advance.
  • Sponsor
It'll vary a bit with year, and what equipment options are in the doors.
Official wiring diagrams don't tend to give a pinout for these connectors I think, you just have to piece it all together from all the pages that cover all the door-located electricals.
Which aren't all conveniently together.
Yes, Thank you. Many a Google reply to a search has contained the expression " look in manual or check schematics". I have been searching for sometime for this mythical part of Skoda manual so yes I am building my own version.
I will check out your pinout thankyou for taking the time.
  • Sponsor
No problem.
What problem are you trying to solve? Presumably busted wires inside bellows?
  • Sponsor
It may be useful to know that the door is fairly easy to completely remove, improving access to both halves of the connector pair immensely. A second person will be handy to support the weight, especially when re-mounting door.
Hi, early last year, I found the majority of the wires in the door hinge were broken. So anyway I replaced the wiring but lock would only lock with the key.
Checked all wires again & all fine so I bought a used door lock but the problem remained plus the second hand lock would also freeze locked when it rained.
Back rummaging in the door again and I found I had missed two wires I checked these & they are to do with the "safe lock".
So my problem is finding where they attach in t28a because everything else apart from the door lock probably due to"safe lock" is working and I would like to mentally repair it using pin assignment before physically returning to the scene of crime.
  • Sponsor
Oh, OK, I can probably find the relevant page of wiring info for that.
I'll start a private message conversation with you to request the VIN, so I can be sure I get the most accurate info.
HI All, As suspected it was the safelock that was stopping the lock from locking!
I had to repin the connection between T28A connector and the safelock switch that on my model sits in the middle of the driver door panel.
