£299 2 year Service Plan
Four months ago I bought a new Fabia 1.5 Monte Carlo. As part of the purchase I paid an extra £299 for the Service Pack which covers the first two scheduled services (not the first two YEARS services).
My car is set from the factory to 'Flexible Servicing' where the car decides when it needs servicing. The dealer didn't ask about my likely mileage (which is less than 2,000 miles per year) and didn't switch my car to an 'Annual Servicing' schedule. The car is now saying something like '600 days until next service'.
The dealer, when asked, has suggested that the Service Pack is for annual servicing and that I need to take it back annually regardless of what the car says. The Service Pack information doesn't say anywhere that it intends the servicing to be annually regardless.
It seems odd that the cars own service requirement doesn't recalculate as it goes along - especially if regular short distance usage is a problem (eg causes the oil to degrade faster). I'm not sure what calculations the car does when set to Flexible Servicing - but it seems odd that it isn't smart enough to cater for all use types and adapt accordingly.
Surely anyone who didn't think about these things would just rock up for their first service when the car says to do so (which could be 18 months plus)?
AI says the below.
Anyone on here have experience of this service package?
I've no experience of your Service Plan. However, based on my own Fabia Mk4 that I bought new in March 2024 (and that I've hardly used since due to personal circumstances) I believe you are over-worrying.
At present, as you've owned your Fabia for just 4 months, the car cannot 'know' what mileage you will be covering in it and cannot calculate whether you are a low-, medium- or high-mileage owner. The standard service time-interval is 2 years, but, as the your car's 1st anniversary approaches and the car 'realises' that it has covered under 2000 miles, it will begin to issue 'count down' dashboard messages saying that an oil-service is due in X-number of days. And, as the 2nd anniversary approaches (and if you've continued to do the same sort of mileage) the same thing will happen.
Thanks Derek.
There's still uncertainty around whether Skoda intend the plan to be for a fixed year 1 and year 2 service. My plan documentation is as clear as mud but I have seen the below online from Skoda .
The sentence doesn't actually make sense (I think it should say 'to the' after the word 'entitlement') but it implies that the service regime (Fixed or Flexible) affects whether you are entitled to buy the Service Plan.....🤔
Does it? Based on what- if it has one of the oil life readouts then they can be fairly good but if it's just a countdown calendar of days to next schedule possibly not so good or good at all, depends on your driving and car use. Lots of short journeys doesn't allow the engine oil to heat up enough. Use your engine oil temperature rather than coolant gauge to see when the engine is warm, 90+c on the oil not coolant.
Always check, double check and cross reference any information you get from any source but much more so with A (so-called, it's not) I, what sensors are there on the car that actually measure engine oil quality - none. - https://www.valvolineglobal.com/en-eur/oil-life-monitors-are-they-really-accurate/
They are A but the language systems are definitely not I - like "smart" devices, they're just the usual very dumb computers and programing.
That is not a good thing for many bits on the car including the engine, have the engine serviced annually if you intend to keep the car longer term. Unless you send the oil for for analysist
Although VWŠkoda don't seem to fully appreciate it with their sales and marketing service and "maintenance" schedules there is more to whole car servicing than just an engine oil and filter change and a look to find chargeable work that may or may not actually need doing.
Get the car "serviced" hopefully they will do the ticksheet checks too, more than 12 months is too long to leave a car without it being looked at, just because it's new doesn't mean there can't be issue(s) that should at least be noted if not attended to.
Ask the Dealership to set the car for annual "services" (fixed) instead of flexible unless you do ten times your current annual milage. (year ago I worked out it was less expensive to have taxi/bus rides than a new car for less than 3,000 miles a year)
As the driver you want to keep on top of the driver's maintenance too don't leave things for once a year (or more) (possibly) checks.
Good luck.
Well, I'm not entirely sure what the service monitor in the Skoda App is telling me then.
Are we saying that, in 2026, a multi billion dollar decades old car giant can't design an in car engine servicing monitoring system that takes into account usage and mileage? And instead they display totally incorrect advice / information? If that is true then it is beyond ridiculous !
My current My Skoda app is showing the following:Screenshot_20260305_213055_Mykoda.jpg
My Superb tells me the same sorted data .
However, mine will be serviced about every 8,000 miles. Also I find it totally ridiculous that a first oil change is scheduled at 10,000, I’m at 3K and the first change was done (not by the dealer of course) at 1,100 miles, a little later than planned, but life gets in the way sometimes.
That is not what I put, in fact I put they're usually reasonably accurate but VW parameters aren't always the best for the car owner particularly if you want to keep the car longer term.
You seem to be saying, the representatives at least, in 2026 of that multi billion dollar, decades old, car giant wrote a sentence that doesn't actually make sense, perhaps they used AI. 😁
It's your car, your choice if you want to wait over 18 months / 18k-miles before "Inspection" and a bit under 18 months / 18k-miles / 16k-miles before having the "Oil change" then that is up to you.
I agree with you that the paragraph you have quoted implies the car dictates the requirement but there might be a further explanation not quoted and/or in the small print of the agreement.
I still wish you luck, it's each to their own for their choices, let us know how you get on with the service plan.
Thanks all.
Slightly off at a tangent, it seems odd to me that super modern (expensive) fully synthetic oil isn't good for at least 20,000 or 2 years (whichever is soonest) in a new modern efficient engine regardlesz of driving habits ir style. We are not talking 1980's Castrol GTX here!
The oil is dependant on its use, or lack of usual expected range of usual use. The fixed terms are just guesses the oil may be best or needing change before or after those fixed terms, it depends on the actual oil used and the use it's put to. The VWŠkoda oil "service" measure is trying to calculate use for when to change the oil.
Then there are different types and grades of synthetic oil but that's another matter.
Synthetic oil isn't that expensive, we in UK like to pay more for car stuff that's partly why VW doesn't mind going to all the effort of making RHD cars to sell over here plus all the profit on their spare parts and oils for those that buy their VW labelled oils and other fluids.
I'm more aware of oils like 1980s Castrol GTX than many here as until a few years ago my one and only everyday use car for the previous 16 years was a 1973 MG Midget (the Mk3 is my wife's car) and having various other old over-priced and over-valued old cars called "classics" as everyday cars (used all year round) including three other MGs over the decades I got to know the MG Owners Club spare parts well and they have the franchise for Castrol Classic Oils (including now GTX). And having many old farts in the "classic" car world I had to justify when I used and suggested Mobil 1 and other synthetic oils, instead of traditional "mineral" oils (with loads of ZZDP), in my "classics" and that others could do the same, decades back.
Up to you but if you want to this professional expert might help you understand (I am NOT an expert in oil or anything else). First a video from him you will like then another you probably won't agree with.
(2026 VW 😄) - 'The Accuracy of OIL LIFE Indicators REVEALED!' - https://www.youtube.com/watch?v=t4e0oDBseqo
(2,000 miles in first year) (and I am a BIG Fan of Owner's Manuals) - 'The FACTS About Oil Changes (What The Owner's Manual DIDN'T Tell You)' - https://www.youtube.com/watch?v=QDxn3mRTOfg
I'm with the sentiments of PongoBongo. I bought outright a new Fabia 4 with service package expecting worry free motoring for a couple of years plus exemplary customer service. The reality has been anything but. It looks to me that buying a car without the backing of a finance package or one of those rolling pcp deals is a bad idea. Once the dealer has had your money they are unlikely to move in your favour.
After the "free" servicing you've paid for is out of the way I suggest the use of a local garage/workshop. If they know you and understand how you are using the car then that's preferable to using a dealer. The latest cars are jammed with electronics though which makes the choice of a local garage more difficult. Our local Skoda dealership is sited in a truly awful location and they have trouble laying on a courtesy car. Standing at the bus stop or walking into the town are scary experiences and booking a taxi seems an insult considering the money I laid out.
I wish that we had bought a ten year old car in pristine condition rather than experiencing the worries that came with our Fabia 4. Dealerships seem to be all sales and minimal customer support.
Find a good VAG indie and stick with them. Even if you're within warranty, having a car serviced outside of the dealer group makes no difference. They'll deny your claim in the same way, after you've paid your inspection fee and been told there is no courtesy car available.
I wouldn't trust a main dealer service department as far as I could throw them - and I have pretty extensive experience with Ford, SEAT and now Skoda. Even BMW have been rubbish - and don't get me started on BMW Motorrad. The only decent service department has been Porsche, but that's practically irrelevant (it was also limited experience with a recall too). My chosen VAG garage can do everything a main dealer can do, and more.
Do you really think Skoda, VW, BMW or anyone else wants to sell you a service plan to help you out as the customer? What sort of business model is that?
They want to keep you trapped into paying endless inspection fees, and £170 for an oil change and cabin filter. Most of the time they don't even do a good/honest/proper job - or at least the ones I've been to don't.
When I bought my Fabia Mk4 new in March 2024 I asked the salesman about servicing time-intervals. I was told that, for low-mileage cars (as mine would definitely be) an oil/filter change would be required at 1-year, as opposed to 2-years for a car that covered a significantly higher mileage, and that a message would appear on the car's instrument cluster when the date for a service approached - and that's what has happened.
With an annual mileage of less than 2000, PongoBongo's car will (like my car) qualify for an oil/filter change at 12 months and another at 24-months. And, based on the cost of my car's first service (at 12 months) the £299 of his Service Pack should provide a useful financial saving over two 'same type' full-price Skoda dealership services (that should include a lot more actions/checks than just changing the engine-oil and oil-filter).
I'd expect PongoBongo's car to recalculate its servicing schedule over time (mine does) but I can't see that matters much when it's clear that his car will require servicing at 12 and 24 months within the Service Plan's lifespan.
There's a striking difference in replies from fellow Skoda sufferers and those who I suspect are forum moderators.
I will start a new thread about the serious issue I've had with our Fabia 4 mc. We've had three alarming breakdowns in less than 2.1/2 years. The dealership has been very unhelpful.
