Coolant issues
Hi
I’m starting to think my 2016 is beyoud saving
I’ve changed thermostat charge cooler heater matrix
Had the head gasket changed on a full engine rebuild
Egr removed and blanked off
Dpf deleted
Yet the car will not stop introducing air into system is it vital to bleed via. Vcds or obd11
Or do can it be achieved by the old fashioned way of burping it
It’s a 2.0 tdi VRs
Coolant air locks can be very persistent, I'd strongly suggest trying a drain and vacuum refill at the very least.
I understand there is also a VCDS bleeding procedure that can be used.
Edited by Warrior193
grammar
Thank you for the response will try that next
Auxiliary pump maybe? At the back lower part of engine
Edited by T07
I’m not getting any fault codes for auxiliary pumps ??
