Fabia Mk2 Vcds Abs
To add to this, I just went to another mechanic for the emissions check. He scanned the car and found fault code P0600 with his diagnostic tool too.
P0600 is a comunication problem with ecu and other units/sensors. Normally an EML or ABS/ traction control light comes on but it could be as simple as a low battery or failing alternator/ poor earth etc
Alasdair
Alasdair
Sure, I will check the battery voltage and terminals, you never know. Thanks
If battery/terminals is good 12.5 - 12.8volt including check earth to chassis then I would check connectors to ecu and abs unit etc to make sure they are secure plus look for visible signs of cable damage especially where its making contact with anything as it may have worn through or been pinched.
Alasdair
