porsche Brake Conversion
Been looking around the net and im hoping to fit a set of porsche boxter calipers that i have seen but wondered if anyone knows if thesed will fit and whats involved in the conversion
Bira apaaerntly do some type of spacer kit but not being technically minded im not sure
If not this kit how do you fit the audi 330mm stuff and what do i need
cheers for any help
mark
You need custom caliper carriers and if planning to use the porsche discs you also need custom bells. I doubt either of these are available seperately as it would do the manufacturers out of the profit of selling full kits.
Plus big enough wheels to go over them with the required offset to clear the wider caliper.
So basically a bad idea then lol think i will stick with the tt conversion
is 312mm the biggest you can do, whats this 330mm conversion ?
I thought there was a 323mm brembo conversion?
yup, as on the leon cupra R :)
WHat size are your brembos Bengie ?
the 323mm LCR ones.
