Heat-pump Query
Hi folks!
I'm interested in a low-mileage/pre-reg Enyaq (or an Elroq)
I want long-range and I'd like a heat pump.
Do any models come with these as standard?
If the specs mention a heat pump - how do I verify this when looking at a car - either through the infotainment system or under the bonnet (or both).
Any recommendations for model / trim combinations?
Cheers,
Zaph
(also, why does this website seem to be broken in that I can't type into it and it doesn't seem to accept end-of-line returns. This was typed in Notepad, then pasted into the webpage, and yes, I have cleared cookies, tried two different browsers on two different machines - never had a problem like this before).
Hi
I wanted to know that about mine so I googled it and came up with this:
'Open the bonnet and have a look for the yellow and black refrigerant sticker above the radiator. If you have a heat pump it’ll be using CO2, which is R744. If it says R1234 then it’s aircon only, no heat pump.' Sadly, mine hasn't got one.
You can also look in your My Skoda app (when you've got it) and under Car Detals there is a link to download a digital certificate which gives an overview of selected info about your vehicle
