Pressure Control Solenoid (N75)
hello
question on the tubo boost solenoid, (n75) in my 1.6 TDI roomster, located to the side of the airbox
. There are a few after market options out there, I wonder if any one has had an issues with these?, the genuine part seems to be around £120 , after market can be about £40
.Im looking to try replacing this first before getting a leak test on the whole vacuum system. as its currently buzzing on and off from time to time.
Reckon if you go for a well known aftermarket like febi,pierburg etc should be ok. I would avoid any manufacturer that you haven't heard of e.g ridex,maxgear
Alasdair
perfect , thankyou for the advise !
  • 5 months later...
hi,
for an update on this issue...
i replaced the solenoid with a Febi brand version.
however..... intermittently, ( at very random times) trouble code still comes back
"turbocharger boost pressure sensor A range/performance" which was the case before replacing the component. in combination with coil light on dashboard.
available throttle/turbo boost does suffer sometimes with this, but not always. and it can go away by turning the engine on and off
