Virtual pedal stopped working - ideas?
Had the car for a month. It took a few days to get the hang of operating the virtual pedal, but I cracked it and it opened and closed every time, but this morning it's stopped working.
Option remains ticked and key is within range. Reset of infotainment didn't work. Any suggestions?
Did you disable the keyless feature? This happened to me. I had to turn it back on, even though I kept the unlock/lock feature disabled when arriving or leaving the car.
I switched off the lock while approaching and walking away feature, next time a tried the pedal it worked as it should. I switched the lock when walking away function back on and it still works.
May or may not be connected, who knows?
Doesn't it say in the manual that it doesn't work well in the rain or if the car is dirty. I gave up on the feature in the end. Too many times kicking the underneath of my boot in the supermarket car park with no result. Quicker to just use the key! 😂
Mine malfunctioned while clean and dry. Suspect it was a software glitch.
Mine stopped working a year ago, I gave up using it.
Car went in for a service this week and after investigation a control unit was replace under warranty, let’s see how long it lasts!
Edited by JamesMW
