VIN for Sedan Sup3 with foldable towing hook - Help
Hi all,
I have a Superb III Sedan (L&K) and recently retrofitted the original foldable/swivelling tow bar.
The installation is complete, but I’m missing the boot trim panel that contains the tow bar release access flap and the status LED. I’m trying to identify the correct OEM trim part number and, if necessary, the associated wiring/connector.
Would anyone with a Superb III Sedan (not Combi) that came from the factory with the foldable tow bar (PR 1D4) be willing to help?
Specifically, I’m looking for:
  • Ideally, a VIN from a factory-equipped Sedan with the foldable tow bar so I can check the exact parts catalogue configuration.
  • Confirmation that the Sedan uses a trim panel with the tow bar release access flap.
  • Photos of the trim panel, front and rear if possible.
  • Photos of the LED and connector on the trim.
  • The trim part number from ETKA.
Any help would be greatly appreciated.
Thanks!
Later Edit: Does the sedan use the same trim cover and flap as Combi? I don't know anyone with a combi so i can take a look
Well, I can guarantee the panel is different, as the "hole" for the luggage compartment is different.
I've found a car for sale so I can show a couple of shots of it:
https://img.classistatic.de/api/v1/mo-prod/images/52/527067b8-ebd8-4ed4-bb18-ed617313f23a?rule=mo-1600
https://img.classistatic.de/api/v1/mo-prod/images/ca/ca16c8bc-e685-4f97-b861-9ce6faee99a0?rule=mo-1600
https://img.classistatic.de/api/v1/mo-prod/images/44/4481f488-98bb-478d-b8d4-8208ef6509c0?rule=mo-1600
