2015 VRS TDI - Coolant loss from expansion tank
1 hour ago, Alasdair1 said:
Seems like the way to go. Hope you don't have to take head off.
Alasdair
Im not hopeful! Ha!
So been over to my mates shed, bypassed the new egr cooler and the issue remains, so it’s off with its head!
There’s a place not far from me that a mate uses for his racing car heads and they’ll pressure test it for cracks and if it passes will check it for warps and if needed skim it.
So onwards. The thought of having to pay a garage to do all of this is terrifying, might take me a bit longer but at least it’s a whole lot cheaper.
I have been doing some searching and have come across a replacement complete engine from a car with 47k on it, seriously considering it as an option, might be easier to just throw a new lump in it at this point.
That may be the way to go depending on how much they want for the engine. You will probably need vcds to code it etc. You could always take the head off anyway off the old one first as it may be just the gasket. If its cracked either take head of other engine or as you said drop complete engine in. Depending on how many miles the car is done maybe factor in a clutch change at same time depending on condition and if its an internal slave do that as well. On a temp basis you could chuck a bottle of steelhead in and see if it improves.
Alasdair
The reason I am considering a replacement is the oil consumption, its not horrendous on it compared to some but its more than I would like. So a low mileage engine seems an option, also considering just getting mine fully rebuilt, but it does all hinge on the head, if its cracked then the cost of a new head and rebuild would probably be too much, if the heads warped / not cracked then a rebuild is a very real option.
Its becoming a "while im in there" sort of situation!
Head is off, no obvious cracks (which is goodish), will be dropping it off on Friday for pressure testing.
I do think there are some areas where it could have been leaking combustion gasses, thats the spots on 2 and 3 there it its got dark soot, not 100% sure but more evidence.
Edited by Sharpy64
Doesnt take much to leak especially exhaust into coolant. Hopefully pressure test comes back good and a new gasket cures it.
Alasdair
Not a small job by any stretch, subframe off, exhaust off, DPF, EGR , turbo all off, charge cooler off. Not something I’d like to be paying for I’ll be honest
My only concern is this “seam”, not sure if this normal or not, aside from that look good.
Some good news, the heads not cracked! So that’s a result, “just” a HG failure. So about spend £1k on parts to put it back together and some “while im in there jobs”.
I will finish this thread once it’s back up and running without issue but it’s been quite the introduction to Skodas. lol.
More progress, sump off and new wet belt for the oil pump fitted, new crank seal and sump back on. Head refitted and rocker cover fitted, all new gaskets for the rocker cover and cam shafts etc.
Turbo refitted with new gaskets and new seals for the return and feed lines.
Dpf and egr cooler fitted with exhaust, all with new gaskets.
New engine mounts fitted.
Cam belt and pulleys refitted and timed up.
Still got quite a bit to get through but all progress.
Edited by Sharpy64
Feels like we are getting there with the rebuild, last night we got
  • Injectors back with all new seals
  • Cooling system largely reconnected (There are sooooo many little coolant hoses!!)
  • Charge air cooler refitted with new gaskets
Seems so little when you write it down but there was so many little fiddly jobs that just ate up time, back at it again tonight, hopefully get it started today, but we have been saying that for the last 2 days... so maybe, maybe not!
Finally, it lives.
First start and test drive complete no obvious leaks and its does feel better to drive.
Something we both noticed was previously the engine was hunting and canting back and forth a bit, that’s all gone as is an odd noise it was making. I feel like that could well have been the head lifting and gasses escaping so something to look out for.
First drive and everything was working getting heat in the cabin and all seems well. Left it at the shed last night on the 4 post to just confirm no leaks but all being well it’ll be back on the road and with luck all my issues will be resolved and I shall close out the thread at that point.
2 hours ago, Sharpy64 said:
Finally, it lives.
IMG_9097.jpegIMG_9098.jpegIMG_9099.jpegIMG_9100.mov
Have you considered fitting hood gas struts to that lovely beast?
I have, but wanted to get it running first! 😆
Yesterday I drove 80 miles and so far so good. All dry around the expansion tank, coolant level dropped a bit but id expect that for the first few days. I am hoping this has resolved the issues.
So to summarise issues,
  • Hunting and canting engine
  • Coolant loss
  • Lots of "soot" out the exhaust
  • Occasional whisps of white smoke from the exhuast
  • No loss of performance was noted
  • No error codes
I started with the EGR cooler as I didnt have coolant escaping from the reservoir, this was tested for leaks and confirmed to be bad so it was replaced. This made coolant spill out of the reservoir.
We spent some time looking at heating / cooling elements like radiator and confirmed a bad thermostat and a possible charge air cooler leak, the latter was suspected as it was quite wet in the cooler. As we were taking the cooler off to replace the thermostat we also replaced the charge cooler.
None of this resolved the complaint so we did and sniff test and confirmed combustion gasses in the cooling system, the earlier test did not show this as a concern. I suspect the EGR cooler was releasing pressure and gasses into the exhaust.
We chose to bypass the EGR cooler to test if it was a new bad part but the issues remained.
So we pulled the head and confirmed there was spots where it was likely that the HG had failed, head tested and confirmed to be okay.
Car rebuilt, all conditions, hunting engine and canting is resolved, smoother drive and generally a nicer place to be.
So, what does all of this mean, how do you know if its HG failure? I would say the easiest way is if you are getting a hunting / canting from the engine and or an subtle but odd "cracking" type noise that cycles with the canting / hunting of the engine. This points to head lift and gasses escaping into the coolant.
The big issue here is that other components could have failed hiding the biggest issue so ultimately a process of detailed diagnosis needs to be undertaken.
If you are reading this and want any advice please reach out as I am happy to help as this has been quite an experience and I now feel like I know quite a bit about these engines!
So for now that closes out this diag and fix thread. Thanks.
Very nice job done!
You also said that you are having some oil consumption, how much?
If you could, would you update has your oil consumption improved after all these repairs with new gaskets etc?
Im also experiencing a bit of oil consumption, like 1,5-2dl of oil used per 1000km, im using 5w-30 Liqui Moly or Mobil1. My motor is 2.0 tdi Cupa engine with 246kkm on the dash.
Suspecting the turbo myself but could also be the oil rings. If driven hard the consumption grows a bit.
Thank you!
  • Coolant loss
  • No error codes
Great work, but could you explain what you mean by engine 'canting'?
52 minutes ago, Jo88Mak said:
Very nice job done!
Thank you!
I would say my feed and return pipes were leaking relatively badly, so I suspect it will be improved but I’ll report back.
The engine was rocking back and forward on the mounts in time with the hunting so there was a link between the hunting and the rocking / odd noise
Another thing I would add is solid engine mounts are not the way to go! It’s a tad vibey…
On 22/08/2026 at 11:44, Jo88Mak said:
Very nice job done!
Thank you!
On oil consumption, I’ve now had the car back a week and while not done massive miles I’ve driven it everyday and cover maybe 30miles everyday at least, so far no noticeable drop in oil. I’m doing a couple of longer drives over the weekend so will feedback again but I’d say it’s definitely improved.
Yeah. Who would have thought the VW engineers designed a way to reduce vibration transfer.....
Are you going to replace with proper engine mount or just tolerate it
Already swapped for Polybush versions, much nicer. I’ve had track cars with solid mounts so knew it would be bad but got them cheap so thought I’d try it.
Found out why they were cheap!
Recently Browsing 1
