Droning noise from front
Can anyone give a clue on a noise apparently coming from the front of the car at 65-70mph in 5th gear. It is quiet at lower and higher speeds. The car is a 2012 greenline 1.6d.
Droning noises are often wheel bearing or tyre issues. That is where I would start, are the tyres okay, any odd wear patterns / feathering on the inner edges, if they are okay then id be checking the wheel bearings.
Thanks. The tyres are new but as I have recently acquired the car, I am not sure about the wheel bearings. I will check them
Will different gear or neutral change noise?
Same thoughts that sharpy but pretty small speed area for noise.
Loose skid plate can do sound also but maybe not that.
If bearing test goes ok then swap rear tyres to front
