Octavia 2 has developed a boot leak
I have a 2012 Octavia 2, bought in 2013, with 10,000 recorded mileage which is 111194.
The vehicle has been reliable but recently has shown signs of having water in the boot. Right now it is bone dry. I use a car port here at home.
Can Briskoda tell me how water might be getting in ? I want to fix this problem before the rains return !
A known candidate is the connection between feed pipes for the screenwasher, IIRC pax side boot to rear of the wheel arch. There are numerous discussions regarding same on here - worth a search.
BTW does the leak water look/feel like what you're putting into your screenwash reservoir under the bonnet?
Another leak candidate would be the tailgate seal, but that would only appear after getting rained on (or carwashed).
Hello. I only experience water/dampness when it rains. I'll get it washed tomorrow while the boot interior is bone dry and look at the tailgate seal.
Today I looked at the spare wheel (in the storage well) which has damp areas and the floor of the well is wet. I will remove the boot lining above the wheel to aid air movement here.
It is likely the hot dry weather is here for another 2 weeks which will help further drying.
Is there water on the seal at the base of the opening for the rear hatch or inside the hatch behind the teim? If so the culprit could be the rubber grommet that goes round the wiper shaft and seals against the glass. That was what the issue was with our Octavia and Kodiaq
I must apologise for not noting that my vehicle is a Greenline model and does not have a rear window wiper. I might also say right now that water in the spare wheel bay is a topic I least expected to cope with.......................................after all this is a SKODA !
I had water getting into mine and puddling in the spare wheel well... It didn't seem to be coming from the screenwash, and trying to mess about with the boot seal only seemed to have a limited effect.
In the end I drilled a few holes in each of the plugs in the bottom of the wheel well to let it all out, it's worked just fine for my purposes!
I found the wheel well has water that is touching the lower treads of the wheel.
I'll add a photo tomorrow. The rubber seal top edge was damp after the car-washand I cannot work out how. I'm sorry to here about crisund123 drilling drainholes. Before I do that I'll try to stop it getting in first.
The boot lid has a circular SKODA badge above the number plate, and tomorrow i'll fill the fine gap round the outside of the badge & the recess it sits in with bluetack. I'll take snaps.
Check also the studs for the boot struts and the bonding of the window to the frame of the hatch, especially at the top.
I had rain water entering the boot through the seals for the rear lights lenses. I removed the lenses cleaned the seals and refitted. The boot has been dry since. Worth cleaning and refitting even if water ingress is from elsewhere as they were very mucky.
Thanks for lenses & struts info.
I've added a photo of the water in the wheel well. My local garage is going to pump it out + I'm going to leave the wheel out of the well as long as the leaking is unsolved.
I'm trying to fill the narrow gap between the badge edge and the recess with blutack just in case rain does come in here. I need to tidy up underneath.............after the car-wash yesterday I found the lid opening button underneath the badge was wet.
Edited by TerenceWallis
add info
With regard to removal of tail-light clusters - how do you do it ? I was hoping to find a tutorial on line but not all light units are the same and I didn't find mine.
I believe the badge is a stick on, no holes or fixings behind.
Thank you.
Here's the wheel well after removing the water. Now the leak hunting fun begins.
Re. the tailgate seal is a candidate for leakage. I was amazed at the amount of rubbish I found in the upper reaches esp. near and at both coiled cables in the guttering.
It's obvious that Skoda have ignored these two areas.
IMG_5407.JPGIMG_5408.JPG5407-5410.jpg When I first considered this gutter area edged with the boot lid seal it was packed with bone dry clutter from the sky. I wondered where water was supposed to be accommodated. With this in mind I intend to keep it scrupulously clear of debris in the future.
The rear light clusters have been removed and inspected and reinstalled. There was no evidence of water damage.
Pressure equalisation vents in behind the two sides of the rear bumper.
