Kamiq spare wheel
My daughter as bought a 22 plate kamiq with no spare wheel/tyre
Her tyres are R 17 s and I understand a spare r17 will not fit in her boot.
Can she put a r16 on her car as a spare get you home if she gets a puncture.
Have a look at this previous thread from two years ago., also titled "Kamiq spare wheel".
Edited by Carlston
You can buy a complete get you home spare wheel kit from Skoda.
Skoda Kamiq Spare Wheel Kit
Link for info but you can order from any dealer
That's a 205/55R16 6Jx16 ET35 5/100 57.1 steel wheel...which is the wrong tyre size for the Kamiq. The correct wheel sizes for the Kamiq are 195/60R16 6Jx16 ET35 (winter tyre size), 205/60R16 6Jx16 ET38, or 205/60R16 6Jx16 ET40. Skoda parts department may have poorly chosen the 205/55R16 tyre size because it's cheaper than the correct tyre sizes for the Kamiq, ie. 195/60R16 or 205/60R16.
Skoda don't approve 205/55R16 for the Kamiq, ie. it won't be in the car's CoC (Certificate of Conformity).
The spare tyre doesn't have to be listed in the car's CoC, so although a non-standard tyre size could be used it's has a much smaller outside diameter than the Skoda approved tyre sizes...as shown in the chart below.
Outside diameter of tyre
205/55R16 631.9mm (not a Skoda recommended tyre size)
195/60R16 640.4mm (winter tyre size)
205/60R16 652.4mm
205/55R17 657.3mm
215/45R18 650.7mm
It's best to order a spare wheel kit without the actual spare wheel (ie. the foam and jack kit), and purchase a spare wheel separately. This way you can select the tyre and rim that you want, and not accept the undersize tyre that VAG parts departments are selling for the Kamiq.
The spare wheel kit (everything, except for the actual spare wheel) can be ordered from "skoda parts com" for about £55 including UK VAT and delivery to the UK from Czech. "skoda parts com" pay the UK 20% VAT, so there's no extra VAT to pay on delivery. It can also be ordered from any VAG parts department, by quoting the relevant OEM part number (eg. 658093860 or 658093860A).
Spare wheel kit (everything, except for the actual spare wheel) (Kamiq) 658093860 658093860A
https://www.skoda-parts.com/spare-part/658093860a-spare-wheel-replacement-kit-skoda-38622.html
Vredestein Ultrac+ 205/60R16 92H (Euro label C A 69dB) (example spare tyre, not a recommendation)
https://www.camskill.co.uk/m62b0s741p227472/Vredestein_Tyres_Car_Vredestein_Ultrac%2B_205_60_R16_92H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_B_Noise%3A_69dB
Although a 205/60R16 should be fitted to either a 6Jx16 ET38 or 6Jx16 ET40 rim, it could also be fitted to a 6Jx16 ET35 rim for use as a spare wheel. However, 205/60R16 6Jx16 ET35 isn't a Skoda approved wheel size (ie. it's not listed in the car's CoC).
Alcar 6664 6Jx16 ET35 5/100 57.1 steel rim (for 195/60R16 winter tyre size) (Kamiq)
https://www.mytyres.co.uk/rims/details?vehicleId=1077003525243802724&rimCode=ALCAR6664
Alcar 6977 6Jx16 ET40 5/100 57.1 steel rim (for 205/60R16 tyre size) (Kamiq)
https://www.mytyres.co.uk/rims/details?vehicleId=1087670437300671588&rimCode=ALCAR6977
Edited by Carlston
