Solved-> Overheating problem Skoda Superb (year 2018)
Hello everyone,
I would like to give feedback to this topic:
https://www.briskoda.net/forums/topic/534598-overheating-problem-skoda-superb-year-2018/
Brothers from the Skoda Superb Facebook group in Turkey solved my problem.
The problem was the lower bumper grille shutters. They were stuck.
I removed the shutters, and now the coolant temperature no longer rises above 90°C under normal driving conditions. It reaches a maximum of 100°C when I drive at 230 km/h with an outside temperature of 26°C.
The oil temperature is still quite high, but I think this is either a different issue or simply normal for these cars.
Best regards
What type of actuator operates the shutters?
Edited by Warrior193
correction
I dont know. I didnt removed the actuator
What's your oil temperature getting to at say 220-230km/h after 3-5 minutes of driving now that the shutters are removed?
My numbers (Mk3 Octavia CUNA TDI 184bhp) are about 107degC - 109degC at 200km/h, about 115degC - 117degC at 215km/h in ca 20degC environment, and I got to 125deg C on one occasion driving at 230km/h before I started watching oil temperature...
I try not to exceed 115degC, even though the engine can take more, the oil pump is belt driven ( and the belt is in the hot oil).
Hi, When I drive for about 10 minutes at 230 km/h, the oil temperature goes up to 137 °C with an outside temperature of 26 °C.
In my opinion, the oil temperature is still quite high when I compare it to my Passat B8 2017 with the same engine.
I also noticed that the ECU is reducing the speed when the oil temperature goes above 135 °C.
I think there is still an issue with the oil temperature, but I can live with the current situation because nobody drives at over 230 km/h for a long time with diesel prices these days.
On a normal drive between 150–180 km/h, the oil temperature does not exceed 120 °C. Based on the input I got from other forums and Facebook groups, the problem could be related to one of the following:
- Oil cooler
- Dirt in the radiators between the AC radiator and the coolant radiator, where the shutters were.
In the future, I will probably clean the radiators and change the oil cooler when I change my oil next time. I will give feedback if I make progress with these.
