Tire pressure value can not be seen on central infotainment display
The Sensors can be a PITA. I had a new sensor fitted front passenger side yesterday before a MOT. It was already showing before i broke the valve as being on the drivers side from the last fitting of All Season tyres as the fitter put wheels to the wrong side. Anyway the MOT tester who fitted the New Sensor pre-mot coded all 4 sensors. Supposedly. After the MOT and a pass he took the car for a road test. When i left the place the Drivers Side was showing 2.4 Bar & 36*oC and the other 3 wheels / tyres 2.2 Bar and 24*oC. I carried on a few miles & thought the new sensor on the Passenger Front would re-set. But no. I stopped off and let them know, but it was closing time for them. So once i have time it will be going back to get coded properly................. Re Setting low pressures. On my BMW you go on the cars screen to the Tyre Size on the Car and Summer or Winter tyres and it recommends the Tyre Pressure range. Then it asks if you want to set to a pressure different from the recommended range. If you do you accept then Set the TPMS as you have inflated the tyres.
Edited by Evolution13
