Kodiaq Seven seater and space saver spare wheel ?
I am shortly hoping to pull the trigger on a new Kodiaq SEL seven seater TDI AWD. This will be my first Kodiaq after three Superb's, all of which lived up to their name perfectly.
The Skoda website configurator allows me to select an optional space saver spare wheel, which is what I need, as every year I get one or two punctures, usually in the middle of nowhere. However, the brochure says that a space saver is not possible in a seven seater.
Assuming the brochure is correct and the configurator is wrong, has anyone managed to fit an 18 inch space saver tidily in the rear of a seven seater with the seats up or down? With the seats up, is there enough space and secure tie downs in the boot for a space saver? I am not concerned about appearance.
I will be adding a few options, so it will be a factory order with projected delivery in November.
1 hour ago, Pesmog said:
...the brochure says that a space saver is not possible in a seven seater...
There are two "foam and jack kits" (which includes everything except for the actual spare saver spare wheel, for the Kodiaq MK2.
One of the "foam and jack kits" is for the Kodiaq MK2 5-seater and the other is for the Kodiaq MK2 7-seater. Neither will fit a hybrid version where the battery is in the spare wheel well.
Both kits are only for a 145/85R18 4Jx18 ET28 space saver spare wheel.
There is room for a space saver spare wheel with the Kodiaq MK2 mild-hybrid (NOT plug-in), because the batteries on these are tiny (probably less than 1kWh capacity) and are fitted under the front passenger seat rather than in the spare wheel well.
Foam and jack kit (Kodiaq MK2 5-seater) 57H093860C
https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/57H093860C
Foam and jack kit (Kodiaq MK2 7-seater) 57H093860D
https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/57H093860D
Space saver spare wheel 145/85R18 4Jx18 ET28 (Kodiaq MK2) 57H601011G
https://eshop.skoda-auto.cz/cs_CZ/rezervni-kolo-18---dojezdove/p/57H601011G
Edited by Carlston
In Greece, we have space saver wheel as standard, in every trim or version-including seven seaters-except the iv version
It's so annoying that they don't give spare wheels on cars, where possible. Those foam kits are a waste of time.
I have a Sportline TDI 4x4 with the 20" wheels, and I use the 19inch spare wheel that I'd bought for my previous Octavia VRS.
It'd picked it up as a kit off of eBay, including a jack and wheel brace. Only bit I had to buy then was the genuine Skoda plastic locking screw that holds the wheel in position.
You can lever the rear sets up after releasing them to get to the original foam insert that has some of the tools, inflator and foam kit. I stored that in the attic and laid the spare wheel in there, and the jack/tools in the centre wrapped in bubble wrap. Works fine for me.
I'm sure you can get a genuine kit it'll include the proper foam insert that surrounds the wheel and holds the tool.
Some links you might find useful:
https://skodapartsdirect.co.uk/product-category/spare-wheel-and-toolkit/
https://shop.wingsskoda.co.uk/products/skoda-spare-wheel-kodiaq-2024
https://shop.parks.uk.com/products/skoda-spare-wheel-kodiaq
I bought a new Kodiaq SE L 7 seater in February this year. Like you, I wanted a space saver wheel. I found the 2 best sources were Skoda Parts Direct and Caffyns Parts. Decided to go with Caffyns. Bought the space saver wheel and the foam kit on their ebay site because delivery was only £12 on eBay but more than £30 if I bought direct from Caffyns!!
Fitted everything myself although some parts are a bit tricky. Guess you won’t have that problem with a factory order.
Thanks for that guys. So it sounds like a space saver will fit in a 4x4 seven seater, its just that I might have to be a bit inventive with the foam trays. 👍
Edited by Pesmog
