PCV valve/assembly
Hi all, What is the signs of a failed PCV valve.. On tick over the car is a bit lumpy, Taking the oil filer cap off when the engine is running, There is a vacuum pulling the filler cap back down and the engine revs speed up. Don't know if this is a sign or not? Thanks..
It might be the PCV, hard to say on modern engines.
That's what should happen with a healthy system.
(Apart from the lumpy idle).
Edited by Breezy_Pete
Thanks for the replies. I'm used to the cars I've had in the past where removing the oil filler cap with engine running has produced the opposite to the Kamiq where crankcase pressure is released through the filler hole...Now i know it's normal.Thanks again
