How to find OEM part numbers of front wheel bearings for my Fabia 2
Hi there. I hope I've not missed something obvious on your forum, but does anyone know how to find OEM part numbers?
My 2011 Fabia 1.2TSI front wheel bearings are getting very noisy. I've looked on various motor factor websites having input my car reg but there
seem to be different dimension assemblies availabe. The only thing I suppose I could is to remove one the bearing/hubs and measure it up but my
wife can't afford to have the car off the road while I order a spare part. I've tried Catcar info but there's no numbers there. The local dealer won't give
me any help which is fair enough. Is there a reliable EPC available to help please? Thanks in advance.
Edited by Rinky380
Go to https://www.lllparts.co.uk/ and browse by manufacturers parts diagram. If you input your vin it will narrow it down. The listings of the bearings may have a PRcode which there is a sticker in boot near spare wheel. You could also try febi parts finder. Find it pretty good.
Alasdair
Thanks for the quick reply and info Alasdair 1. I didn't know about the PR codes but now I've checked them all and unfortunately the sticker doesn't have what I need. I've visited the link you've provided where there's a chose of two part numbers but as I don't have the PR code I can't be sure which part I need. They really don't make it easy! Regarding the puller is it a Gen2 puller that's required? Thanks for your help.
Gen2 bearing type that needs special tooling to make sure you don't press on the hub face when installing.
Search youtube for demo vids with tooling examples.
Edited by Breezy_Pete
First one, ending E. There have been some superseding numbers but they usually quote all that match on the aftermarket.
Great stuff Breezy_Pete. That's just what I need. I've got access to a hydraulic press but I'll get Gen2 tool kit to be on the safe side. Thanks a lot.
Had to spend a bit of time cleaning up bearing socket on my sons. Especially the grooves it clicks into due to corosion. Fairly easy to do with the correct puller. Couldnt get ABS sensor out without destroying it. Give it a good soak with penetrating oil for a day or two and you will hopefully be lucky.
Alasdair
By coincidence I had an ABS fault recently which was caused by a faulty front speed sensor so I ended up replacing both of them. They were completely siezed in so I ended up carefully drilling them out. I drilled down about a centimetre theh heated the end of a screw which was inserted into the remaining length of the sensor and it popped out with no damage to the bearing. I lubricated the new ones well so their removal should be easy. Out of interest I used Febi replacements and they've been working fine.
I'll be sure to clean off any corrosion as you suggest.
Also with sensor fault the DSG box was awful on changes. Apparently the mechatronic uses a speed sensor input. It was back working beautifully again after the sensors were replaced.
Used febi ones as well and no problems. Put a slight smear of copper grease on bit that fits in hole not the tip for future removal. According to youtube the new bearings should click in place when fully home. I didnt hear anything but they went in as far as the old ones. Took a photo of the old ones in place before removal for reference.
Sons were really loud but no play and we only noticed once I finally fixed his blowing flexi exaust. Just got to do front swing arms and bushes now,
Alasdair
Yeah I used copper grease like you for the sensors. I'll be getting around to the swing arms and bushes at some point too.
Better to remove the newish ABS wheel sensors before using a Gen2 kit on these bearings - I got away with it on one side but not on the other side!
It was just the typical "from China" copy kit that I bought, just make sure that you line everything up so that you apply the force "in line", failure to do that, in extreme cases, will end up with the kit's thrust bearing track snapping - so it seems from someone on another forum, you can buy new thrust bearings on ebay though, I needed to do that when I snapped a bearing track on the lower arm rear mounting kit!
Edit:- I ended up buying a couple of bearing assemblies from autodoc it was FAG that I chose. I had already checked on the FAG website that I was ordering the correct bearing.
Probably other places selling FAG in UK now at a good price, it was Tayna that I used when buying SKF wheel bearing packs for my 2011 Audi S4 as they had them at the right price.
Edited by rum4mo
To get you started on part numbers, I've checked what I ordered for a 2015 VW Polo 1.2TSI 110PS a few years ago, and it looks like your 2011 Fabia 1.2TSI uses the same "72mm" front bearing assembly complete with ABS pick up ring.
The VW Group p/n started as being 6R0 407 621 A and that was superseded by 6C0 407 621 and that has been superseded by 6RD 407 621 A.
Now, when I ordered my bearing assemblies a few years ago, the FAG offering was 713 6104 and the SKF offering was VKBA3569 - of course with time FAG and SKF might have revised their offerings.
Each of these aftermarket kits comes complete with a new plastic dust/debris shield and a new hub nut.
It might also be time to check the condition of the disc back plates as they will be getting removed to do this work - I spent an hour of so cleaning mine up - threw some black paint on them - then just bought new ones as in reality there was not much good steel where it needed to be!
Thanks for the part numbers. You're right about back plates as mine have definitely seen better days. I was hoping to remove them to give me more access to the speed sensors but the screws were really badly corroded in and I was short on time as my wife needed the car. I'm going to order a pair of plates up and will probably end up drilling the screws out and retapping the threads.
One of the screws isn't possible to get 'square onto' with bearing/hub in place, so a bugger to do anything with once corrosion has taken its toll on the head.
Some one might correct me, but if you don't already know, it tends to be the heads of the backing plate covers that get bonded with rust to the backing plates, once that bond is broken you should find that the threads are clean and the screws can be unscrewed by hand.
Stupidly I considered that the same situation should/would be the same when taking the disc dust covers off my 2011 Audi S4 - not so, some design clown made sure that one screw hole was open at the back so I snapped one screw head off - I only did that on one side!
Edit:- ah yes, the one that is tricky to get a tool onto - I had properly established what the correct size/version of bit was to fit onto the easier ones, then using the correct 1/4" bit, got that fitted into the cleaned out recess in that screw head, then wedged/jammed it down in there by driving maybe 2 small screwdrivers between the lower face of the hub and the top of the 1/4" hex bit - then used a small adjustable spanner to turn the 1/4" hex bit - that worked for the tricky one on each side.
Edited by rum4mo
added in info.
