Searching for the correct coding for 5F: Information Electronics after changing the sound settings with Car Scanner
I own Skoda Octavia mk3 1.4 TSI August 2017 with MIB 2.5 (5Q0 035 874 C) and I was experimenting with Car Scanner and decided to improve the sound using it.
After experimenting, I decided not to change anything and selected the original value and saved it… But I overlooked the fact that I should have reverted the changes using the special button. In that case, the original coding would have been preserved instead of whatever coding Car Scanner generated for me. But ultimately, it was my fault.
So, I currently have incorrect coding, and there is one and only one error stored in the 5F module and it's an eyesore:
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 874 C HW: 5Q0 035 874 C
Component: MU-S-ND-ER H41 0480
Serial number: SKZAZ2T5328145
Dataset Number: V03935267DK 0001
Coding: 03730201FF00000051111201008802232F0208D401200500CE
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 34311CCD3EB8917A8B3-8060
Display and control head 1 for information electronics:
Subsystem 1 — Part No SW: 5E0 919 605 M HW: 5E0 919 605 M
Component: ABT_Std-2_Nav H50 8130
Serial number: SKZ6ZHT2374035
Data carrier:
Subsystem 2 — Part No SW: V03 959 821 BJ HW: -----------
Component: ECE1 2024/25 --- 2210
Serial number: --------------------
1 Fault Found
1590 — invalid data record
B2005 00 [00001001] — —
[Control module (data record download) — invalid data record for sound audio parameters]
Confirmed — Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 89079 km
Date: 2026.08.18
Time: 21:14:53
Voltage terminal 30: 11.9 V
Does anyone know how to determine the correct coding so that this error disappears?
Edited by metabacalhau
Dataset Error is No Coding...
You need correct Dataset
Edited by Cairus
Thanks, makes sense!
Do you know what dataset I need for my unit? I tried to search here https://mibsolution.one/#/1/9/Datasets/MQB/5F by my unit number 5Q0035874C and couldn't find anyting.
I Upload here in View Minutes
Adress dataset 3000&3600
Bin File later when you need it
3000er.xml 3600er.xml
