Broken spark plug - ruined engine? 1.4TSI CZCA
Afternoon all, is this as bad as I think it is?
Bad noise, check engine light, error codes P0300, P0302, P0303. Changed ignition coils on cylinders 2 and 3 which didn't solve the problem so checked the spark plugs. Spark plug on cylinder 2 was missing the tip! It appears to have broken off while in use! The spark plugs were changed 2.5 years ago with Bosch ones. Picture of broken spark plug and video of bad noise attached.
Is my brothers diagnosis of "might need a new engine" an accurate one? I'm hoping I can fish the piece out with a long thin magnet, stick a new spark plug in and then everything will be good as new again!
Car is a Golf 1.4TSI mk7.5 with the CZCA engine.
Cheers
Welcome to the forum.
The noise is probably the missing plug electrode bouncing around inside the cylinder - don't run the engine any more until any foreign bodies have been removed!
I'd suggest using a borescope to inspect the cylinder head, valves and top of piston for damage.
The missing outer electrode is possibly ferrous, you may be able to remove it using a magnetic probe.
Pretty sure they are steel but it may have embedded itself into piston. As warrior193 said do not run engine at all and get it inspected via borescope. Hopefully it will be retrievable without removing head or caused any major damage.
Alasdair
Thanks. I'm hoping no major damage was done as I only drove a couple of miles with the noise.
Gonna try and find a long thin magnet and see if that can fish it out. Plus it gives my bro an excuse to buy a borescope! Will let you know what we find...
Unfortunately a few miles, even at low revs is many thousands of piston cycles in the cylinder - and yours is an 'interference' engine, meaning there is almost no clearance between piston crown and cylinder head!
never drive engine with any noise. stop at moment.
try to find missing part. easiest thru spark plug hole. if valves are not damaged, it will go.
if cilinder wall is damaged, its old school cast iron cilinder wall liners which can be machined. no new engine needed.
Does the alloy-block EA211 use cast iron liners?
1.4 yes, only 1.5 no.
Had a look inside with a Borescope and took these pictures. Definitely some marking on both the valves and the pistons but nothing on the cylinder walls, bad enough to warrant replacing the valves? Not a small job!
Also no sign of the piece of spark plug! Working theory is that it's been smashed up inside the cylinder and blown out the back.
Next step is to do a compression test.
Is that a round crater I can see in one of the valves (images 3&4)?
A lot of pitting on piston crown - I'd suspect that could lead to issues given the conditions during combustion.
If the compression test comes back good then hopefully its just surface damage to valves and pistons and the valves are still sealing ok. As long as theres definitly no sign of bit of sparkplug I would see if the noise is still there and carefully start engine. Any noise switch it off quickly. You may be lucky and as said just surface damage. By the look of the marks the sparkplug may have been well worn and only a small bit was left that broke off,
Alasdair
Compression test was good! 13bar in all 4 cylinders. Have put 4 new spark plugs on and just driven to the shops and back with no issues!
So it looks like my bro was wrong and it doesn't need a new engine. Perhaps I was lucky and have got away with just a bit of surface damage.
Cheers for the help
Glad its superficial damage and alls well. You were lucky. Could have been a lot worse.
Alasdair
