1.0l TSI SE suitable for private hire use ?
I'm currently looking at purchasing a car for work, taxi driver.
Only ever driven octavias 1.6 tdi and recently 1.5tsi act.
Test drove a 1.0 tsi se yesterday and was surprised how well it drove, was expecting it to be sluggish with a considerably smaller engine than I'm used to.
Will mainly be used short stop start journeys with an old dear and shopping in the boot with the occasional boot full of suitcases with 4 extra bodies going to the airport
Bit of gogogling suggests carbon build may be an issue that'd need monitoring, anything else i need to know to help make a decision ?
I assume you have factored the lower cost of petrol against the higher MPG of a TDI?
Four passengers with suitcases would suggest a Combi as opposed to a Hatch - If going down the TSI route, suggest looking for a 1.0TSI 110 or 116PS engined version, which, for a manual, have the 6-speed box.
Edited by Warrior193
correction
Even with the advances in engines these days I think you'll find that if you ever travel fully loaded with passengers and luggage the car will struggle.
A car may appear nippy when it's just yourself driving (the default situation for many cars) but if you have the opportunity, try a test drive "fully loaded" to see how suitable a workhorse it may be.
Our local taxis drive a lot of octavias. Reckon every second one is one. Last one I was in was a 1.0tsi and taxi driver said it was excellent. I too was really surprised when he said it was only a 1.0 litre. It felt like my 1.6tdi
Alasdair
When relative engine power is considered, it was pretty common in the past for a private taxi to have a 1.8 or a 2 litre NA engine - a modern 1.0TSI matches that at lower RPM !
added information
My old 1.9tdi and newer 1.6tdi are 105hp which is less than the 1.0tsi. Torque on my diesels is 250NM which is higher than the 200NM of the 1.0tsi but reckon as long as your not towing you wouldn't notice.
Alasdair
