Ottocast issues
Hi. Is anyone using an ottocast mini cube? I got one recently and it will only work sometimes. Sometimes it will work after a bit but mostly it stays trying to connect with the car. Comes up usb connection failed then trys again and again.
Sometimes it will connect straight away. Don't know if it's the car, the ottocast or my phone.
Just wondering if anyone had similar issues
Had the same on our Kodiaq and gave up with it. I replaced it with an AAWireless2 that works flawlessly
i have ottocast, but flat one. sometimes it wont self connect, then i manually tapping on display few times and after few times it connects, in settings i choose to connect when phone is off, so when i enter in the car, start engine, i dont turn of multimedia till 1 minute pass. then it connects itself good, sometimes about 2 of 100 connections fails, then manually reconnection fix problem.
Hi. I have the cheapest one I could find on AliExpress and it has literally worked flawlessly since the day I got it.
https://a.aliexpress.com/_Ex5BdpG
Edited by Binx1310
https://a.aliexpress.com/_EQeRtHo
I bought a cheap one before and it wouldn't work at all
I bought that one because Bink said it worked and cheap, been faultless
I first bought a cheepone off amazon but had problems with sound from Waze and Google maps, changed to an Ottocast Pico, thinking the button may reconnect easily, but that isnt the case, i have to have bluetooth on to connect first, then it uses the wifi , when the nav app sound doesnt work i just remove the ottocast and reinsert it, the sound then starts ( found it is the same with the cheap unit i had too
I read on here before about updating the firmware on the ottocast to correct some issues. No idea how that’s done.
My Ali express one connects within a few seconds and auto plays from where you left off. It’s been plugged in permanently for nearly a year and had no issues whatsoever.
I might try one of the ali express ones.
Recently Browsing 2
