1.6 TDi Greenline glow plug replacement
I got an emissions system warning light on a trip to Prague recently on my 186,000 mileage 2016 Skoda Superb 1.6 TDi Greenline. The car drove fine, all the way back to London.
My diagnostics tablet indicated a glow plug fault on Cylinder 1. When I clear the fault it returns within a day or two, usually after a cool morning start.
I already have torque wrenches, a socket set, a set of large circlip pliers and penetrating oil.
This morning I've ordered a Bosch glow plug (BOS0250403009) from GSF, as well as a Wolfbox MF100 battery electric air blower and and Liqui Moly glow plug grease from ebay.
I'll be using the circlip pliers to help remove the electrical connection. And a combination of penetrating oil and a torque wrench and a hot engine and patience over a few days to remove the old glow plug.
Fingers crossed that this will be a straight-forward DIY job...
I would reconsider the glow plug grease. You'll get mixed reports if you should use it. It comes out of the factory without and using it changes torque settings.
I did one recently and was prepared for the worst, but once cracked, it was finger tight. I did leave it soaking in wd40 for a few days though. You can use a multimeter to check it for continuity first, just in case it’s the cable:
Congrats on it not being cylinder 3 btw.
When I changed a glow plug, I sprayed it when hot and cold with WD40 specialist penetrant for about 3 weeks leading up to being brave enough to try taking it out.
https://www.eurocarparts.com/p/wd-40-specialist-penetrant-400ml-542771790?utm_source=google&utm_medium=cpc&utm_campaign=610675635&utm_content=70461851759&utm_term=&type=shopping&gad_source=1&gad_campaignid=610675635&gbraid=0AAAAAD1aCJiCH00Nb1y-9oNagakWazLWg&gclid=CjwKCAjwifjVBhBKEiwAYx4K9Gr4esDsqkYF07vtj-SUlNoa99sUK64kWpMgQefPCrCN5MJdWU_ttRoCb-IQAvD_BwE
It came out ok but took quite a bit of force (And bravery) to crack it initially. But they can be very hit and miss!
So far I've given it 2 sprays with penetrating oil. And 1 blast with the Wolfbox air blower. It looks clean around the glow plug now.
I will give it a go with my small torque wrench, going up to 30 NM maximum to loosen it, after my next daytime drive...
Agree with using the penetrating oil but, when the time comes, use a T-bar wrench so that you apply a pure torque, this minimises the risk of snapping the glowplug.
🤞for you!
