Driver's Door Electrics
My 2011 Superb Elegance has developed a weird fault with some electrical features, but just on the driver's door:
  1. Central locking works on all doors - except the driver's door
  2. Left (passenger side) door mirror can be adjusted from door control, but not the driver's door.
  3. The driver's door mirror does not heat up or fold in.
I've checked the fuses but they are all OK, but I can't understand how one fuse could be responsible without affecting the other linked electricals.
Does anyone have any ideas regarding this? Thanks in advance.
  • Sponsor
Broken wires in driver's door bellows.
Super common.
Yep. I'd agree, my 2014 had some issues with the locking, found several broken wires and wires with insulation cracked.
DIY repair if you are comfortable messing about with wires/soldering etc.
I suspect the passenger door and boot lid going the same way unfortunately...age, repeated bending/stretching and material quality all an issue here.
check the wiring inside the rubber tube that goes from the door to the door post on the car. the wiring can break in there and cause intermittent problems
