VRS brakes on a 1.2/12v HTP
As I changed the brakes of my VRS 288 to 300mm, what do I need to put these discs and calipers on our 1.2/12v HTP?
1 hour ago, Erreesse said:
...as I changed the brakes of my VRS 288 to 300mm...
I think you mean 310mm/312mm rather than 300mm.
The 288mm front brakes use separate brake caliper carriers, whereas the smaller 256mm front brakes use brake caliper carriers that are built into the steering knuckle (aka the wheelbearing housing).
Therefore, when upgrading from 256mm to 288mm front brake, the steering knuckle needs to be changed...as well as the front brake discs, front brake calipers, and front brake caliper carriers.
The Fabia MK2 models that come with the 288mm front brakes as as standard appear to be the models that have at least 105PS. So if a 1.2TSI, 1.9TDI, 1.6TDI, etc. has less than 105PS it's fitted with the smaller 256mm front brakes. This information might help you to source the parts needed for a 288mm front brake upgrade from a suitable donor car.
The OEM part numbers can be obtained from a Fabia MK2 parts diagram, such as LLLPARTS.
When you get to lllparts.co.uk type in lllparts.co.uk/catalogs manually...if you are having problems getting to the Skoda parts diagrams...and you might have to sometimes refresh the page manually because of the anti-robot software lllparts uses.
Notice below, that the front brake pads for the 288mm front brake discs are available with and without a wear indicator...so it's easy to match what the car currently has.
These 288mm front brakes are used on the VW Polo MK4 and the various Seat and Skoda clones, including the Fabia MK1, Fabia MK2, and Roomster. The Fabia MK1 VRS uses these same 288mm front brakes but they are painted green and hence have different OEM part numbers and a different build code (1LP).
Fabia Mk2 parts diagram (288mm front brakes) (TRW brake system) (Build code 1LN)
6Q0615123
Brake caliper housing
left
1LN
6Q0615124
right
1LN
6Q0615125
brake carrier with
pad retaining pin
left
1LN
6Q0615126
brake carrier with
pad retaining pin
right
1LN
1J0615301R
Brake disc (vented)
D >> - 24.05.2009
288x25mm 5/100
1LN
6R0615301A
Brake disc (vented)
D - 25.05.2009>>
288x25mm 5/100
1LN
6Q0698151A
1 set of brake pads for
disk brake
1LN+9U0
6Q0698151C
1 set: brake pads with
wear indicator for disc
brake
1LN+9U1
Steering Knuckle (Wheel bearing housing) (288mm front brakes) (Build code 1LN)
6Q0407255S
left
1LN
6Q0407256S
right
1LN
Edited by Carlston
Recently Browsing 2
