Heater Matrix Flush??
Hi all please help! SKODA OCTAVIA 1.5 TSI 2018
Interior heater blowing cold driver side and on off hot passenger side, has anyone done a heater Matrix Flush/Full coolant Flush and does it actually work?? Because New Matrix + Labour is approx £600 😵
Is a Flush worth a try??
I can't seem to see any silica bag in my Tank, maybe its there and maybe its split open not sure. What yall saying?
Kind Regards
Edited by DMAC23
To be honest the biggest faff with heater matrix is draining the coolant and then if you flushed it, disconnecting pipes, might as well bite the bullet and replace, not sure flushing would be that effective (I replaced mine).
Lots of blocked matrix threads going on!
Yeah, I think the main work is the refill procedure and pipe connections.
I think the actual matrix is fairly easy to access
Hi. Are you sure the cause is the heater matrix and not the climatronics passenger side flapmotor that controls the hot and cold airflow. In LHD vehicles its V159 i think.
These flapmotors are known to fail when they age, the potentiometer inside fails or the plastic stop breaks so that the motor loses its position signal.
Have you read DTCs?
Also do you have G13 coolant and does it read in your expansion bottle "Mit silikat"?
Three garages told me to replace matrix for heater working driver side only, had main rad replaced after it split, garage vacuum filled coolant system, heater has worked perfectly ever since (5 years ago)
This was a French garage and they said the main issue was casting material, not the silicat bag, which holds very little material.
Some time later had thermostat replaced, the pipes around that area were full of casting sand.
Is it possible to get to pipes that feed matrix from engine bay. Remove them from engine/coolant system and flush through with garden hose leaving matrix in situ?
Alasdair
If you can access the heater matrix hose connections in the firewall and disconnect the hoses you can:
  • Like Alasdair said flush with a garden hose
  • Blow compressed air in the "input"-connection and catch the outcoming fluid from the "output"-connection, careful dont blow too hard, it will make a mess
  • Tape a long clear hose that you can feed in to the heater matrix to a wet vacuum cleaners nozzle and vacuum the coolant off from inside the matrix
Recently Browsing 1
