First impressions
My new 2l TDI SE L Estate was delivered yesterday lunchtime, so not had much time with it yet. I have moved from a 2018 2l tsi executive hatch to this tdi estate. Firstly I thought in the short drive I had that it was very responsive, but the ride was much firmer and the bumps felt more. I will check tyre pressures today. I felt the car was in sports mode and was disapointed to find there are no driving modes, so obviously not in sports. Checked I hadn't moved into Sports on gear selector. That will take a bit of getting used to, I kept putting my left hand down when I wanted to reverse. I went for a quick 10 mile run up the motorway and tried the ACC, which was fine. I came home on A roads and town work, and all seems fine. I have already found out how to get rid of the nannying features and switch them off. Unfortunately not permenantly. The infotainment screen is a steep learning curve, for instance, I eventually found the radio, but when I moved on to a different screen I couldn't find it again. That's a job for today along with fitting my dash cam So first impressions overall are good; I'm not unhappy!
After 8 months with my Mk4 I still occasionally find my left hand pawing the air trying to find the reverse gear selector 😕
There should be a Music icon at the bottom of the infotainment screen to get you back to the radio settings. Otherwise, the Home icon at the bottom right is your friend - wherever you get lost in the maze of screens it will take you back to the main page so you can start searching again.
I recommend spending a little time to customise the icons at the top of the screen. Decide what you will need most often and put them there; it makes a real difference for ease-of-use when driving. For example, I have the Auto Hold selector because I need to turn it on and off when moving in and out of my garage. That means I can select it with one tap instead of hunting through menus.
Recently Browsing 2
