Ceratec diesel additive to Octavia mk3 2.0 tdi
Hello folks,
I am planning to add ceratec engine additive with the engine oil during my next service.
But, can I use the additive with Octavia 2.0 tdi mk3 which has a wet clutch?
I was confused because Liqui moly website says that the additive is not suitable for wet clutch systems
1) Is the additive only not suitable with dsg gear oil and can be added to engine oil?
2) Is the additive not suitable even to engine oil with wet clutch dsg?
3) Does the engine oil come in contact with wet clutch or gear system?
Please let me know if anyone has experience regarding this. Thanks!
Hello,
Liqui Moly Ceratec is only a engine oil additive only, It does not go in the gearbox dsg oil at all and are two completely separate systems. I think they put that disclaimer to make sure its not to be used in the wrong place. To confirm can be used in cars with a DSG box but its not gearbox additive in any shape.
So you add it to the oil you minus some engine oil 300ml and add a bottle of ceratac to prevent over filling, That how we have used it.
35 minutes ago, MeteorG said:
Hello,
Thanks for your reply. I will go ahead and buy it then.
I don't know why you would put an additive in the oil.
The recommended oil for VAG group engines is to the highest fully synthetic oil specifications and why it is relatively expensive.
Good enough for endurance racing engines.
Recently Browsing 2
