Perplexing braking problem
Hello all. New to the forum, and relatively new to skoda... I have a really puzzling issue i hope someone can help with
I have a 2015 fabia mk3 1.4 diesel. Purchased last year. About 6 months ago the brakes developed a pulsation... as if they were snatching rather than biting, so lurching on braking.
Took to garage. Warped front discs. Replaced... and about a month later the pulsation returned... same warped discs. Replaced again... now on the 3rd set and its back again.
So further investigation undertaken at garage. They ran the car under braking and managed to get the brake temp up to 90 degrees, but brakes were still releasing as they should with no binding.
Important... also NO warning or fault lights on the dash
So according to the mechanic that eliminates calipers and master cylinder. They do have a vague theory but they are really unsure and ive already had someone else say they can't be right so rather than put it in people's heads ill let people throw there own thoughts at me first.
I really hope this can be sorted as I do like the car and would rather not let it go. Any help would be greatly appreciated
Hub damaged due to heavy kerbing at some point in its life - they should have checked hub face runout after the first replacement discs "went bad".
Recently Browsing 1
