Play in between outer and inner track rod end
Just got some new tyres Michelin ps5 for the fabia that were in black Friday deal.
Tyre fitter noticed 3 to 9 o'clock play across tyre on front left wheel. Showed me it moving near lock nut which was tight.
Fitted inner track rod ends 55k ago but both outer track rod ends had split on rubber. I fitted lemforder outer TREs and new ball joints then wheel alignment. March 2025.
The play seems to be the thread holding the outer and inner TR together.
So, do I just replace 1. inner and outer TRE?
  1. Both sides inner tre and outer tree?
  1. Do both sides and think about new shocks and springs, top mounts, drop links (55k miles, 9 years on) in case shocks are problem.
At 65k last shocks were toasted but suspect due to previous owner. However on our watch rear shocks were hitting bump stops after 30k miles.
Don't you just love doing these jobs in the cold 🥶
If 3. Other than a dealer where should I get all fasteners for the strut?
Ps same number of threads visible on both track rod joints on both sides of front axle.This pic shows the affected side but really doesn't show anything unless you watch video
Edited by bmbmdmb
The thread on the inner TR is in the steering rack - so is the inner track rod tightened up correctly to the rack - or has its ball joint failed - which brand of parts were used.
Surely, with an assistant you can work out which end is causing this problem.
Edit:- I hate working on cars when it is near freezing - crap happens though!!
Edited by rum4mo
Why does it look like the TRE lock nut is not bearing up tightly to the TRE end?
Rum4mo
The looseness appears to be between the track rod ends! Just to right of locknut in photo, but lock nut is done up tight.
QuoteWhy does it look like the TRE lock nut is not bearing up tightly to the TRE end?
Mechanic said you can get your nail in that gap as it opened and closed, but I've had a go at tightening lock nut with wheel off ground and it is tight. That photo was taken before getting home so maybe it did tighten up slightly. Kwik fit assured me if lock nut was loose I'd quickly get adverse symptoms with steering...
I've tugged on inner track rod ball end and it has no play. The outer tre with rubber seal is not damaged and swivels as normal. Nut is tight.
Weird situation. I repainter calipers in summer and this play in wheel wasn't present.
Lemforder outer tre
Possibly Delphi or similar inner tre
Edited by bmbmdmb
It might just be the picture, but the thread on that track rod looks pretty mashed up, which probably doesn't bode well for the state of the lock nut of the thread in the end. For how little money they are, I'd probably think about throwing a complete new rod and end on the car.
For suspension parts, I normally try to get a FeBi / Bilstein part, they probably made the one that was originally on the car
