vrs 2003 windows/sunroof closure via remote ??
Hi all
Does anyone know if this is programmable via vag-com ?
cheers
nigel
before you try getting it programmed in, have you tried putting your key into the lock and turning it as far clock wise as it will go and holding it there for 10 seconds. If this doesnt do anything try turning and holding if fully anti clockwise for 10 seconds.
I cant remember which way to turn it on mine but one of the ways works on mine
dont know about the roof but obviously my windows close off the door lock but can you programme it to close windows off the remote like on the new octy.
Is the key trick works then you will need an alientech controller (well I did on my 2001 TDi)....
The alien window kit is Octavia only.
Cheers for that, yup it does work on the key.
Seems a pretty weird thing to 'design' in if you can call it that, works on the key but not on the remote, doh !
As far as I am aware, my car is standard, but if the windows are open, and you lock the car, it closes them automatically.
